Malcolm_Ball
Joined: Sun Sep 30, 2007 4:37 pm Posts: 298 Location: RM13 ish
 Re: Handbrake
I've not long gone this route, so rough description from front - backwards.
Origional K3/Metro handbrake fitted with the T shaped 'balancer' from 400/600
Cables and mountings from 400/600
Calipers from 820 - the mounting holes almost line up, just need a couple of mm filed out, the brackets the hold the cable outer may need to be altered.
Disks - from memory these were skimmed to 10mm thick
_________________ Malcolm GTM(s) & VAG PD130 oil burner.
| Sun Aug 31, 2008 9:02 pm |
bob snooks (835)
Joined: Sat Sep 29, 2007 3:45 pm Posts: 207 Location: SL2 4JW
 Re: Handbrake
MGF 240mm rear disc's come 10 mm thick.
| Sun Aug 31, 2008 9:17 pm |
Peter B
Joined: Tue Aug 26, 2008 9:15 pm Posts: 19 Location: Bedford
 Re: Handbrake
Thanks for the information Malcolm, are you using 13" wheels or bigger? Thanks Peter
| Sun Aug 31, 2008 9:39 pm |
Bryn
Joined: Sat Jun 07, 2008 11:23 am Posts: 8 Location: Wrexham
 Re:
gtmdriver wrote: I made my own cables for the Coupe. What exactly are you looking for? Are they totally unique or are they shortened versions of standard cables? Hi John, How do you go about fitting cable ends? I have some brake cables with no end fittings at all and was thinking of machining some up in stainless and soldering them on?
| Sun Aug 31, 2008 10:35 pm |
gtmdriver
Joined: Tue Oct 30, 2007 8:44 am Posts: 449 Location: Chester le Street
 Re: Handbrake
I used pre-made nipples from Vehicle Wiring Services but stainless will be fine too. To be safe I silver soldered mine on. It's a lot stronger than soft solder. You could crimp them in a vice before you solder if you really want to be sure.
_________________ GRP rules!
| Tue Sep 02, 2008 11:16 am |
John SS
 Re: Handbrake
Many thanks Malcolm and all others for the info - I will start collecting bits for the winter project! However, I would also like to know if the calipers will still clear my 13" Metro GTi wheels, please?
| Wed Sep 03, 2008 2:18 pm |
Bryn
 Re: Handbrake
gtmdriver wrote: I used pre-made nipples from Vehicle Wiring Services but stainless will be fine too. To be safe I silver soldered mine on. It's a lot stronger than soft solder. You could crimp them in a vice before you solder if you really want to be sure. Thanks for the tips John. Those vehicle wiring chaps have some useful bits. Looks like I’ll be buying a few more bits from them.
| Wed Sep 03, 2008 8:36 pm |
Bryn
 Re: Handbrake
John SS wrote: Many thanks Malcolm and all others for the info - I will start collecting bits for the winter project! However, I would also like to know if the calipers will still clear my 13" Metro GTi wheels, please? The MGF disc is a thinner version of the Metro disc of the same diameter and height, so I would say the calipers will clear the wheels okay.
| Wed Sep 03, 2008 8:39 pm |
Malcolm_Ball
 Re: Handbrake
Peter B wrote: Thanks for the information Malcolm, are you using 13" wheels or bigger? Thanks Peter 13's ??Team Dynamics?? theres next 2 no gap caliper to rim at the rear and about 1/4 inch at the front.
| Thu Sep 04, 2008 10:04 pm |
John SS
 Re: Handbrake
Malcolm, please can I clarify a couple of things from your previous post;
"Calipers from 820 - the mounting holes almost line up, just need a couple of mm filed out, the brackets the hold the cable outer may need to be altered.
Disks - from memory these were skimmed to 10mm thick"
1) I assume you were fixing these to standard metro hubs? 2) why did the disks need skimming - mine are 10mm. Or have they worn down?!
Thanks for your help, John
| Mon Nov 10, 2008 3:34 pm |
Pantera2075
Joined: Fri Oct 12, 2007 9:38 am Posts: 698 Location: Stoke
 Re: Handbrake
Have you guys seen this post from the 16vminiforum? http://www.16vminiclub.com/forums/viewtopic.php?t=13723At the bottom there's a very interesting bit on Golf brakes - which appears to be on a Coupe from the pics (Apologies if it's anyone already on here) Edit: Duh, just read it again - it's on an ABS Freestyle.
_________________ It's got to be frunky.
| Mon Nov 10, 2008 5:26 pm |
Malcolm_Ball
 Re: Handbrake
John SS wrote: Malcolm, please can I clarify a couple of things from your previous post;
Thanks for your help, John 1/ Yes metro hubs 2/ Can't remember for the life of me why, but I know it was done.
| Tue Nov 11, 2008 12:15 am |
John SS
 Re: Handbrake
Many thanks Malcolm. Waiting for some bits to arrive and to see whether I can make it all fit! John
| Tue Nov 11, 2008 5:51 pm |
