It is currently Fri Sep 25, 2026 10:20 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
Handbrake
Post Re: Handbrake
I've not long gone this route, so rough description from front - backwards.
Origional K3/Metro handbrake fitted with the T shaped 'balancer' from 400/600
Cables and mountings from 400/600
Calipers from 820 - the mounting holes almost line up, just need a couple of mm filed out, the brackets the hold the cable outer may need to be altered.
Disks - from memory these were skimmed to 10mm thick
Sun Aug 31, 2008 9:02 pm
Post Re: Handbrake
MGF 240mm rear disc's come 10 mm thick.
Bob S.
GTMOC Secretary
Sun Aug 31, 2008 9:17 pm
Post Re: Handbrake
Thanks for the information Malcolm, are you using 13" wheels or bigger?
Thanks Peter
Sun Aug 31, 2008 9:39 pm
Post Re:
gtmdriver wrote:
Hi John,
How do you go about fitting cable ends? I have some brake cables with no end fittings at all and was thinking of machining some up in stainless and soldering them on?
Sun Aug 31, 2008 10:35 pm
Post Re: Handbrake
I used pre-made nipples from Vehicle Wiring Services but stainless will be fine too. To be safe I silver soldered mine on. It's a lot stronger than soft solder. You could crimp them in a vice before you solder if you really want to be sure.
Tue Sep 02, 2008 11:16 am
Post Re: Handbrake
Many thanks Malcolm and all others for the info - I will start collecting bits for the winter project!
However, I would also like to know if the calipers will still clear my 13" Metro GTi wheels, please?
Wed Sep 03, 2008 2:18 pm
Post Re: Handbrake
Thanks for the tips John. Those vehicle wiring chaps have some useful bits. Looks like I’ll be buying a few more bits from them.
Wed Sep 03, 2008 8:36 pm
Post Re: Handbrake
The MGF disc is a thinner version of the Metro disc of the same diameter and height, so I would say the calipers will clear the wheels okay.
Wed Sep 03, 2008 8:39 pm
Post Re: Handbrake
Thanks Peter
13's ??Team Dynamics?? theres next 2 no gap caliper to rim at the rear and about 1/4 inch at the front.
Thu Sep 04, 2008 10:04 pm
Post Re: Handbrake
Malcolm, please can I clarify a couple of things from your previous post;
"Calipers from 820 - the mounting holes almost line up, just need a couple of mm filed out, the brackets the hold the cable outer may need to be altered.
Disks - from memory these were skimmed to 10mm thick"
1) I assume you were fixing these to standard metro hubs?
2) why did the disks need skimming - mine are 10mm. Or have they worn down?!
Thanks for your help,
Mon Nov 10, 2008 3:34 pm
Post Re: Handbrake
Have you guys seen this post from the 16vminiforum?
http://www.16vminiclub.com/forums/viewtopic.php?t=13723
At the bottom there's a very interesting bit on Golf brakes - which appears to be on a Coupe from the pics (Apologies if it's anyone already on here)
Edit: Duh, just read it again - it's on an ABS Freestyle.
Mon Nov 10, 2008 5:26 pm
Post Re: Handbrake
1/ Yes metro hubs
2/ Can't remember for the life of me why, but I know it was done.
Tue Nov 11, 2008 12:15 am
Post Re: Handbrake
Many thanks Malcolm.
Waiting for some bits to arrive and to see whether I can make it all fit!
Tue Nov 11, 2008 5:51 pm
