flippspeed
Joined: Tue May 01, 2012 8:40 pm Posts: 190 Location: hampshire GTM: Cox/Coupe
 front indicators
hi people any one got any ideas or pictures of some decent front indicators to use on the coupes
| Thu Nov 29, 2012 9:50 pm |
Mr Mac
 Re: front indicators
I used Wipac NAS spec land rover units as I did on the rear.
| Thu Nov 29, 2012 10:46 pm |
flippspeed
hi mr mac did you fit them quite close to the radiator opening so they sit flatter
| Thu Nov 29, 2012 10:55 pm |
Mr Mac
No, directly under the headlights. They fit fine, the curviture of the body is no problem at this point. I'll take some pics this weekend.
| Fri Nov 30, 2012 12:12 am |
MiniMike
Joined: Wed Sep 28, 2011 4:13 am Posts: 143 Location: Victoria BC Canada GTM: Cox/Coupe
I am looking for the same thing, as the ones I have on the front now are some Toyota ones that do not fit the curve and are looking pretty tatty. So now looking for other options.. for our rules here they need to be combination of parking lamp and turn signal.. are the Wipac ones dual filament?
_________________ MiniMike in Victoria 1989 GTM Coupe - SOLD 1989 Mini 30 VTEC powered 1966 Mini Van Honda ZC powered
| Fri Nov 30, 2012 1:09 am |
Ken555
Nissan Micra K11 side ones are nice and small. rRRUegeBMc!1nl26!~~_35.JPG) Also available in White/clear if you look I was looking at Fiat Punto ones also
| Fri Nov 30, 2012 1:10 pm |
gtmdriver
I used the normal Mini ones but I recessed them slightly.
_________________ GRP rules!
| Fri Nov 30, 2012 7:43 pm |
flippspeed
thanks for the replys guys its a real help ,ken555 is that 501 bulb if so how does that work being a 5w bulb or is there some thing else ive missed
| Fri Nov 30, 2012 9:02 pm |
MiniMike
gtmdriver, how far did you recess the lights?
ken555 - are the Nissan Micras ones dual filament?
Thanks in advance!
| Fri Nov 30, 2012 9:32 pm |
Mr Mac
| Fri Nov 30, 2012 9:35 pm |
Ken555
flippspeed wrote: ken555 is that 501 bulb if so how does that work being a 5w bulb or is there some thing else ive missed  Yes its a 5w bulb, I modified an electronic relay to flash at the required speed. MOT just checks for an indicator, not how bright. minimike wrote: ken555 - are the Nissan Micras ones dual filament? Afraid not, but you could wire something up I would guess. My Headlights are "angel eyes" type so no sidelight lights required.
| Fri Nov 30, 2012 9:40 pm |
MiniMike
Yes, I can fit a dual socket behind although a lot of the newer light housings are plastic molded sockets so not the easiest, as need to keep it watertight from the rear... another option is use some relays to make it work for both park and signal?
Good idea Mr. Mac! That place does not ship outside the UK.. but I may be able to find them elsewhere..I would prefer the 70mm size though..
| Fri Nov 30, 2012 10:33 pm |
Mr Mac
Just search eBay for NAS Wipac and you will find loads of people selling them. Failing that try any of the aftermarket land rover online shops.
If you want me to buy them and ship them let me know - not a problem although it might cost a bit in postage.
| Fri Nov 30, 2012 11:05 pm |
gtmdriver
MiniMike wrote: gtmdriver, how far did you recess the lights?
Thanks in advance! I recessed them so that they were square across the car but the outer edge was flush with the body panel.
| Sat Dec 01, 2012 6:00 pm |
MiniMike
A subtle but effective way to mount them.. thanks.. I have a few options to think about..I think maybe a trip to the breakers to poke around might help sort something out..
| Sat Dec 01, 2012 6:40 pm |
