Re: Hi spec performance brakes
Ooo that sounds interesting, I'll have to check that out if their going to be at Stoneleigh.
I haven't any experience of aftermarket electric handbrakes but I've had modern road cars with them and they work perfectly so expect the Hi-Spec one will to.....no more handbrake turns though
Be nice to dump the cables etc as well, bit of weight saving.
Have you got a bias pedal box or a rear pressure limiter? It sounds as if those rears would need to be dialled back just a bit to balance the braking out. Otherwise you'll have to be very careful not to lock the rears when trail braking into the corners or the wet. Once that happens a visit to the local landscape is inevitable
(I speak from bitter experience) You know all this already though. What rear brakes are you currently running?
Would love to see some pictures when you get the kit. I expect a brake upgrade will be the first thing I do after my car's been on the road for a while, its running std metro gti / rover 220 kit at the moment with EBC discs and pads - probably adequate at best as I really like strong brakes in a car.
