Yoda74
 Re: Rear wheels
Hi John, Is your rear steer locking systeem the same as mine? 1/2" thread Is it complete with locking nuts? As you can see, the thread on the left Side got butchered. Is it possible to send them to Holland? If so, how long will it take them to arrive here? Greets Harold
| Fri Mar 25, 2016 11:57 am |
kano nordie
 Re: Rear wheels
Hi Harold, I made arms to replace the Mini steering arms and left and right hand M12 threaded links with spherical bearings and a nut with a shank to fit onto the upper arm spindle, the same idea as the Rossa Parts steering locking system. I'll be back in the UK on 18th April and they could be posted to you if still needed. I'll take a picture of the steering lock and post it, Its too hot (45c) whoooo outside just now John
| Fri Mar 25, 2016 1:44 pm |
Yoda74
 Re: Rear wheels
Hi John,
Is it a straight bolt on?
In between now and then I will have a look around and see if I can find something suitable around here. Or have it made maybe. Can you e-mail me your price?
I'll keep you informed
Cheers Harold
| Fri Mar 25, 2016 2:38 pm |
kano nordie
 Re: Rear wheels
It is a straight bolt on apart from having to drill 2 extra holes in the subframe for the support bracket on the inner pivot, just a thought are you using 13" wheels? as they would not fit inside a 10" wheels, that is why the Mini steering arms are such a funny shape John
| Fri Mar 25, 2016 5:38 pm |
Yoda74
 Re: Rear wheels
Yes, my wheels are 13", so it should fit.
| Fri Mar 25, 2016 6:16 pm |
Yoda74
 Re: Rear wheels
The trackrodends on both sides of the adjust-bar are not he same?! The one on the outside which connects the adjust-bar to the steering arm has a balljoint with 3/8 thread and a tapered piece from aprox 11,5 to 12,5mm The one on the inside which connects the adjust-bar to the subframe has a balljoint with 7/16 thread and a tapered piece from aprox 13 to 14mm. Must be British Sense to make them different, but are they standard mini parts? The one on the wheelside probably is the standard trackrodend from a mini steeringrack? http://minispares.com/product/Classic/S ... 0to%20shopWhat about the one on the inside? Cheers Harold
| Sat Mar 26, 2016 9:20 am |
kano nordie
 Re: Rear wheels
Help - anybody using this tapered ball pin setup, I have only seen it once on a GTM and that was way back in early 1980's so did not check sizes
| Sat Mar 26, 2016 11:19 am |
 Re: Rear wheels
| Sat Mar 26, 2016 12:04 pm |
Starmag
 Re: Rear wheels
Rossabitz does a steering locking kit, might be worth dropping him a PM?
| Sat Mar 26, 2016 12:33 pm |
Yoda74
 Re: Rear wheels
Thanks guys, I just e-mailed Alan/Rossabitz. Hopefully he will be my next Hero.
Cheers Harold
| Sat Mar 26, 2016 1:15 pm |
kano nordie
 Re: Rear wheels
Try Allan at Rossabitz or Austin A60 Cambridge on fleabay
| Sat Mar 26, 2016 2:34 pm |
Yoda74
 Re: Rear wheels
My two new steer-locking kits have arrived! Many thanks to Alan @ Rossabitz A nice package of trackrods, nuts and inner trackrodends. The outside-trackrodends are standard mini-parts and I allready bought these. Hopefully they will be fit next weekend. Cheers Harold
| Wed Apr 13, 2016 7:10 am |
kano nordie
 Re: Rear wheels
Fit today, you could be driving by weekend John
| Wed Apr 13, 2016 8:14 am |
Yoda74
 Re: Rear wheels
It will be raining next weekend.... ofcourse... And unfortunately no time today... Got to make some money to later on see it disappear in the drain called GTM...
| Wed Apr 13, 2016 9:03 am |
kano nordie
 Re: Rear wheels
 Many of us know that drain very well, mine also has a Jedi and a few old Italian bike in the drain, but no wife John
| Wed Apr 13, 2016 9:26 am |
