It is currently Sun Jun 14, 2026 11:12 am
Dampers and hydrogas suspension and build manual
Post Dampers and hydrogas suspension and build manual
Should my K3 have had dampers as well as the hydragas spheres as I have seen on some other rover/bl cars using the spheres?
Also is there a pdf copy of the build manual anywhere I can buy or download?
Last question , how many K3s were built?
Wed Jan 11, 2017 4:02 pm
Post Re: Dampers and hydrogas suspension and build manual
It depends on which donor metro was used. If it was a gti then they had the dampers as well as the spheres but other metro's didn't have them on so it really doesn't matter whether they are fitted or not if the spheres are in good shape.
I have a copy of the build manual which I can scan and send as pdf if you like. I will dig it out. From memory it's not brilliant but it may be useful.
I don't think many K3s were produced because the Libra took off not long after but I would be curious as to how many were produced.
Peter.
Thu Jan 12, 2017 2:08 pm
Thankyou Peter re the scan that would be great.
Regards
malcolm
Thu Jan 12, 2017 5:16 pm
My K3 (years ago now) had spheres with no dampers.
RossaBitz has build manuals
Not sure
And welcome
Thu Jan 12, 2017 8:00 pm
hi, If you pm me your address I will post you the manual
Peter.
Mon Feb 06, 2017 6:18 pm
Hi Peter
Thankyou for your kind offer but I have found a copy of the manual now.
Regards
Tue Feb 07, 2017 8:40 am
Ok, no worries, enjoy meddling!!!
Peter.
Tue Feb 07, 2017 11:04 am
Metro GTi had dampers on front, but the K3 without welding in some brackets won't have a top mount (as it was on the body not the subframe on the Metro).
Wed Mar 01, 2017 1:00 pm
Hi in this post you can see how my dampers are fitted to my car
k3-anti-roll-bars-t3463.html
Wed Mar 01, 2017 2:54 pm
