It is currently Sat Nov 21, 2026 11:10 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
coilover brackets
Post Re: coilover brackets
Hi J, yes I can weld them for you, only takes 10 minutes so no extra cost.
Peter.
Tue Oct 31, 2017 7:23 pm
Peter.
Peter
You have PM
J.
Tue Oct 31, 2017 8:55 pm
PEEPS wrote:
I have used the MGF rear anti roll bar which fits on brackets hung from the rear subframe mounts. There is a tiny bit of clearance needed where it bends but it should work fine. Though I have used the MGF rear suspension setup. You will see what I mean.
Peter
Did you have any clearance issues at the body tub mountings for the MGF tie bar set up?
Sat Jan 06, 2018 5:53 pm
I take it these would fit a Metro/R100 front subframe?
If so I would be interested in an assembled pair if they are still available?
Sat Jan 06, 2018 6:34 pm
Hi John,
Using the MGF subframe you will need to cut off the outside brackets as shown in the photo. The subframe will then fit into the tub mounts using the long bolt shown. The tie bar is not affected.
Mon Jan 08, 2018 2:26 pm
Peter
Perfect, as I was was concerned that the front trailing arm mount would foul and judging by some of your other photos, the TF subframe could be a possibility too.
Tue Jan 09, 2018 6:20 am
Hi i have just bought my first GTM K3 and im looking to ditch the hydragas and move over to coilovers are these brackets still avaliable.
Thanks Ian
Wed Oct 24, 2018 2:47 pm
Hi Ian,
Yes they are, i've just had some more cut so they will be available. £30.00 per axle set + £12.00 postage. The backs are the same as the fronts but with the extra bracket on for the torque tube fixing.
Peter.
Wed Oct 24, 2018 3:25 pm
Excellent Peter put me down for a full car set and the best way of paying you for them
Wed Oct 24, 2018 3:57 pm
peter soon all the k3 will have your coilover brackets on them
Sun Oct 28, 2018 3:07 pm
hi peter
on the front passenger side do you no if the coilover bracket
hits the heater fan box
Image Image
thanks paul
Sun Nov 04, 2018 11:54 am
Paul.
When I built up my K3 using PEEPS brackets, there was clearance for the heater box, as the height is only a few mm taller than the hydragas spheres but sadly I cannot find a photo showing it fitted.
For reference, the MGTF front strut towers are taller than PEEPS brackets and there was plenty of clearance as shown on my K3 thread.
J.
Sun Nov 04, 2018 7:20 pm
hi thanks that will help
im having fun trying to get my ARB to have some clearance.
i have a plan just need to see if will work
thanks paul
Sun Nov 04, 2018 8:06 pm
Are these coil over brackets still available?
Tue Jun 25, 2019 6:27 pm
