PEEPS
 Re: coilover brackets
Hi J, yes I can weld them for you, only takes 10 minutes so no extra cost. Peter.
| Tue Oct 31, 2017 7:23 pm |
jaybee
PEEPS wrote: Hi J, yes I can weld them for you, only takes 10 minutes so no extra cost. Peter. Peter You have PM J.
| Tue Oct 31, 2017 8:55 pm |
jaybee
PEEPS wrote: I have used the MGF rear anti roll bar which fits on brackets hung from the rear subframe mounts. There is a tiny bit of clearance needed where it bends but it should work fine. Though I have used the MGF rear suspension setup. You will see what I mean. Peter Did you have any clearance issues at the body tub mountings for the MGF tie bar set up? Thanks John
| Sat Jan 06, 2018 5:53 pm |
roger
I take it these would fit a Metro/R100 front subframe?
If so I would be interested in an assembled pair if they are still available?
| Sat Jan 06, 2018 6:34 pm |
PEEPS
Hi John, Using the MGF subframe you will need to cut off the outside brackets as shown in the photo. The subframe will then fit into the tub mounts using the long bolt shown. The tie bar is not affected.
| Mon Jan 08, 2018 2:26 pm |
jaybee
Peter
Perfect, as I was was concerned that the front trailing arm mount would foul and judging by some of your other photos, the TF subframe could be a possibility too.
| Tue Jan 09, 2018 6:20 am |
IAN 51
Hi i have just bought my first GTM K3 and im looking to ditch the hydragas and move over to coilovers are these brackets still avaliable.
Thanks Ian
| Wed Oct 24, 2018 2:47 pm |
PEEPS
Hi Ian, Yes they are, i've just had some more cut so they will be available. £30.00 per axle set + £12.00 postage. The backs are the same as the fronts but with the extra bracket on for the torque tube fixing. Peter.
| Wed Oct 24, 2018 3:25 pm |
IAN 51
Excellent Peter put me down for a full car set and the best way of paying you for them
| Wed Oct 24, 2018 3:57 pm |
catsam
peter soon all the k3 will have your coilover brackets on them
| Sun Oct 28, 2018 3:07 pm |
catsam
hi peter on the front passenger side do you no if the coilover bracket hits the heater fan box  thanks paul
| Sun Nov 04, 2018 11:54 am |
jaybee
Paul. When I built up my K3 using PEEPS brackets, there was clearance for the heater box, as the height is only a few mm taller than the hydragas spheres but sadly I cannot find a photo showing it fitted. For reference, the MGTF front strut towers are taller than PEEPS brackets and there was plenty of clearance as shown on my K3 thread.   J.
| Sun Nov 04, 2018 7:20 pm |
catsam
hi thanks that will help im having fun trying to get my ARB to have some clearance. i have a plan just need to see if will work thanks paul
| Sun Nov 04, 2018 8:06 pm |
Chops
Joined: Sun Oct 08, 2017 7:08 pm Posts: 100 Location: Accrington, Lancs. GTM: K3
Are these coil over brackets still available?
| Tue Jun 25, 2019 6:27 pm |
