thunderossa
 Re: Rossa Mk11 weight saving
Sounds like a plan I will post you some pictures of my car in the next few weeks. My son is at uni and is useing it as a chassis project. I dont want to show the frame untill he has run it through the computer and confirmed it is safe.
| Tue Aug 05, 2008 10:01 pm |
Allan
My Mk2 Rossa in road trim was well over 800 Kilos. I seem to remember that a selling point of the K3 was that the body tub itself was lighter than a Mk2.
And my Mk2 without its roof bolted on had the torsional rigidity of trifle. So be careful where you remove weight from.
| Fri Aug 08, 2008 2:52 am |
Allen7
http://www.ijohnson.demon.co.uk/gtmoc/rossa.htm quotes Rossa at 700kg and K3 at 820kg, wonder if they're the wrong way round? Anyone got original brochures with quoted weights?
| Fri Aug 08, 2008 9:27 pm |
RaymondH
I have an original brochure for the Mk1 and it says 700 kgs in road trim.
| Sat Aug 09, 2008 7:58 pm |
Allen7
If my Rossa II was driveable right now I'd put it on a weighbridge to find out.
Anyone got any more weights quoted or actually weighed?
| Sun Aug 10, 2008 8:03 pm |
Allan
I did say body tub  and it was a magazine quote. As for my car it was fuelled to go with spare wheel, roll hoop, roof etc. But I put it on a proper weighbridge with no driver or luggage 840kg.
| Tue Aug 12, 2008 1:42 am |
Allen7
840 kg - interesting, seems like I'll have to work harder to save weight and aim for more bhp
| Tue Aug 12, 2008 9:27 pm |
thunderossa
Hello These figures sound alot when you consider that a standard Mini in road trim weighs 720 How did they ever sell it as a sports car?
| Wed Aug 13, 2008 12:47 pm |
Allan
Mine was never remotely intended as a lightweight. I think I could easily have dropped 40kg without a lot of work at all. But I only actually measured it the once and I thought I'd let you know what it was. I'd be interested to know if anyone else measures theirs.
| Thu Aug 14, 2008 3:03 am |
Allen7
OK, I weighed a few bits (bathroom scales).
Rear lower section of bodywork (bit with bumper, lights and luggage bay) - 15KG
Engine cover section 12 KG.
Will weigh other bits as convenient - would anyone else be able to post weights?
Regards,
Allen
| Sun Sep 07, 2008 7:13 pm |
Allen7
Well, car is mobile (if not actually mot'd  ) Weighed on local public weigh bridge, accurate to 20KG I believe) All up weight (hard top, tank 1/4 full, no driver or tools) = 780KG Not very scientific but front of car (edge of bidge to middle of wheelbase) = 390KG Rear of car (edge of bridge to middle of wheelbase) = 430KG (as I under stand it the front and rear weights should add together to make the total ) Good news is that I've saved 300 grams fitting a new set of different wheel nuts Guess a full cage will add a good 25KG Anyone else weighed anything recently?
| Thu Jan 08, 2009 9:27 pm |
Malcolm_Ball
Allen7 wrote: Anyone else weighed anything recently? Yes - 14 stone + Yours, Unhappy Essex
| Thu Jan 08, 2009 11:50 pm |
Allen7
Further weight savings:- Removed engine cover hinges and now fitted with dzus fasteners - saved 2 KG Recaro seat weighed at 19 1/2 KG  One seat Remove seats replace with non recliner seats at 6 3/4 KG each seat Total weight saved so far 27KG and 800gms Only down side, new seats are a bit on the snug side Regards, Allen
| Sun Apr 12, 2009 9:48 pm |
Allen7
Now stripped out the dash and mini heater. Replacing heater (4 KG) with one weighing 1.2KG. Attachment:
!BdtJbIgBWk~$(KGrHqUH-D8ErGWvg!9(BK6HF8SEjg~~_35[1].jpg [ 9.31 KiB | Viewed 10822 times ]
Also have an Acewell digidash to fit, so should save more weight. Total weight saving so far 30.5 KG Regards, Allen
| Sun Dec 27, 2009 9:25 pm |
Allen7
Acewell dash and heater fitted, complete with new dash, saving about 5 kg. Total now approx 35.5 KG
Allen
| Sun Apr 04, 2010 9:54 pm |
