jaybee
 Re: Just Got Myself A 1995 1.4 Twin Cam K3
Shiny  J.
| Mon Jun 25, 2018 8:08 pm |
catsam
hi did you use the mgf engine mounts when i did my engine change to the 1.8 i could not use the mgf one without modifying it to follow the metro one so it would miss the bulkhead the red one was cut to follow the shape of the mero one  my mgf handbrake cabals i think are fixed to the sub fram using p clips
| Mon Jun 25, 2018 8:30 pm |
jaybee
catsam wrote: hi did you use the mgf engine mounts when i did my engine change to the 1.8 i could not use the mgf one without modifying it to follow the metro one so it would miss the bulkhead the red one was cut to follow the shape of the mero one  my mgf handbrake cabals i thin are fixed to the sub fram using p clips Paul I used the standard F gearbox mount and I have about 1mm clearance at the near side bulkhead. Thanks for the tip on the handbrake cables, as I was trying to replicate the MG route, which is over the top of the gearbox and then p-clip to the GTM rear clam frame. As I don’t want to cut into the body tub, I am searching to see what slave cylinder brackets are fitted to othe k-series models and hope to find a quick solution, J.
| Mon Jun 25, 2018 8:41 pm |
jaybee
Well, I had a little play last night and have hit a problem with the rear clam frame fouling on the MGF rear anti roll bar - I originally took the ARB off to allow me space to fit the coil over set up and when I offered it back up last night, it fouls on the rear clam frame; therefore, has anyone managed to fit the ARB without serious butchery of the rear metalwork?
J.
| Wed Jun 27, 2018 9:34 am |
tonygerrard(1049)
Hi Jaybee, Where did you get your nice shiny manifold and is there any difference to 1.6 & 1.8?
| Wed Jun 27, 2018 9:40 am |
jaybee
tonygerrard(1049) wrote: Hi Jaybee, Where did you get your nice shiny manifold and is there any difference to 1.6 & 1.8? It was thrown in as part of the deal for me to buy the full MGF rear end and as far as I am aware, it does all K-Series engines. I was looking at this one and they have dropped the price as tad https://www.ebay.co.uk/itm/STAINLESS-ST ... SwZ65a6HxSJ.
| Wed Jun 27, 2018 9:51 am |
jaybee
| Mon Jul 02, 2018 11:07 am |
PEEPS
This is how it looked with the cat installed. It pushed the box out too far and would have needed surgery to the rear clam so I made my own. Peeps.
File comment: I tried the MGF box but it required too much surgery to the rear clam. Ended up making my own noisy jobby.
| Mon Jul 02, 2018 4:22 pm |
jaybee
PEEPS wrote: This is how it looked with the cat installed. It pushed the box out too far and would have needed surgery to the rear clam so I made my own. Peeps. Peter. Many thanks for that, it’ll save me a lot of hassle. Did you manage to get the rear clam frame to fit properly with the rear anti roll bar in place? J.
| Mon Jul 02, 2018 8:08 pm |
PEEPS
Hi J, No, I did away with the original box section horror, fastened the arb to the mount brackets as shown and made my own adjustable clam pivot plates that bolted directly to the subframe.
| Tue Jul 03, 2018 10:44 am |
jaybee
PEEPS wrote: Hi J, No, I did away with the original box section horror, fastened the arb to the mount brackets as shown and made my own adjustable clam pivot plates that bolted directly to the subframe. Thanks!! Do you have any photos of the clam mounts? J.
| Tue Jul 03, 2018 11:41 am |
PEEPS
Hi J, The triangular piece that takes the pivots originally was hanging off so I removed it, bonded in a couple of stiffeners and then bonded in a couple of stainless brackets which then lined up with the subframe brackets. These gave me 30mm adjustment up and down and in and out. I will see if I can find the original drawings for the subframe mounts, I had these laser cut (surprise!) and welded one into an 'L' shape for the other to bolt to. Peter.
| Tue Jul 03, 2018 3:19 pm |
jaybee
| Mon Jul 09, 2018 3:44 pm |
