It is currently Sun Aug 16, 2026 8:56 am
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23  Next
Paul's k3
Post Re: Paul's k3
I have put some of the wire in for the radio
Image Image
I will have to make a small cover to fit over the radio to cover up the hole for the old clock I don't know how this will look :?:
Wed Feb 26, 2020 9:59 am
Post Re: Paul's k3
The radio is in and work's I have cut the hole bigger but as I thought I will have to cut into where the clock was
so now there is a big hole at the top of the radio, for now, I will make a cover and see how this looks if it looks rubbish I will change it
I have made a small cover for the hole a bit of black paint and I think it will look ok
i think this will work
Thu Mar 19, 2020 7:33 am
Post Re: Paul's k3
I have put some black paint on the cover it looks much better than I thought it would
Image Image
Still, a lot of tidying up to do but I think it will work I have to make a bracket to fix the radio in the car um CAD time
Wed Apr 01, 2020 1:16 pm
Post Re: Paul's k3
catsam wrote:
Have got the head back in one part all new seals and cam to replace the broken one
Do you have an idiot guide to getting the head back together? I started to strip mine down & now in a panic trying to put it back togther
Alan..
Tue Apr 07, 2020 2:24 pm
Post Re: Paul's k3
I have made a bracket for the radio well two the 1st one did not work
Image Image Image Image
Allan do you have a copy the RAVE CD from rove.
I did have a link http://www.touchepower.talktalk.net/VVC_Timing.htm
but it has stopped working I did print this out I will see if I can scan it
I also found this https://wiki.seloc.org/a/VVC_Information a little way down the page might help
Tue Apr 07, 2020 6:08 pm
Post Re: Paul's k3
I used to have a copy, but don't use Windows anymore but will have a look to see if I have it & whether it will run under Wine
Alan..
Wed Apr 08, 2020 8:57 am
Post Re: Paul's k3
:roll: I have got my car all back together and I can't take it anywhere :roll:
Image Image
the radio is not blurry it's just the phones camera
I have a much bigger picture now when I put the car in reverse (it's my garage door )
Image Image
Wed Apr 08, 2020 9:15 am
Post Re: Paul's k3
Very smart
Wed Apr 08, 2020 10:28 am
Post Re: Paul's k3
sanzomat wrote:
Very smart
It is isn't it, I wish now I'd kept the dash out of the MGF I stripped last year, having problems catching the dash with my knee on the Metro one fitted
Wed Apr 08, 2020 10:40 am
Post Re: Paul's k3
Its a sham i can't say the same about my door cards they are looking i bit roppy
I was going to get them re trimmed but can't get them done with the way things are
I was looking at something which might last longer
Paint or some plastick coating
what have over people used
Mon Apr 20, 2020 9:14 am
Post Re: Paul's k3
Mine just has fibreglass panels, do you have the measurements for the roll bar, possibly more images of where you picked the fixing points up from?
Mon Apr 20, 2020 9:18 am
Post Re: Paul's k3
Strange what has happened to that vinyl cloth. I guess it is not UV stable and the sun has damaged it but surprising it would happen so quickly as wasn't that a fairly recent re-trim? The vinyl on my Spyder door cards and dash is still fine after 16 years but the car has always been garaged so only sees the sun when it comes out to play so maybe that is a factor.
Mon Apr 20, 2020 10:49 am
Post Re: Paul's k3
Hi i don't have any sizes for the roll bar what I did was to make a pat
ton from some 15mm copper pipe to make sure that it would fit with the hard top and soft top on
I made a goal post-shaped roll bar I then welded some square feet to the bottom.
the car had a roll bar at some point in the past Someone one had cut holes
In the front of the big square box on the tub so I could just get a bolt into the hole to fix the feet to the tub
The bars that run to the back pick up the torque tub bolts from the engine bay
They were made with the main bar in place as the tub was a different shape
On each side
Made to fit my car
Mon Apr 20, 2020 11:02 am
Post Re: Paul's k3
My car is also in a garage and only comes out in the sun I think I will see if i can get the company that did the job to have a look and see what they say
Mon Apr 20, 2020 11:07 am
Post Re: Paul's k3
My headlights have stopped working I have taken the headlight bulb out to see it better my main headlights have stopped working I have sidelights and full beam but no main the dim dip relay is not working
Here is a link to what I did to fix it
http://www.gtmdrivers.com/forum/headlig ... t4477.html
Sun Apr 26, 2020 2:42 pm
