It is currently Fri Nov 20, 2026 10:26 pm
K3/Metro Pedal box failure
Post K3/Metro Pedal box failure
Hi all, just wanted to do a warning message to all with K3s with the modified metro pedal box. Mine just failed on me rendering me without brakes or clutch.
Mines a factory built car so probably a few similar cars out there so worth a check if it looks a bit thin!
Pictures to follow!
Wed Sep 23, 2020 1:20 pm
Post Re: K3/Metro Pedal box failure
hi thanks for the warning message
if you mean the brake pedal broke they were all made in the factory.
the metro pedals required to be shortened and this was undertaken by GTM on an exchange basis.
I will have look at my one as I have changed the pedal ratio brake-upgrade-for-k3-t3742.html
Thu Sep 24, 2020 12:03 pm
Photos below - seems to have failed at the bolt hole and spread from there - was only attached with one bolt in my on that side which is also a bit concerning!
Been around the rest of the car with a VERY fine comb looking for similar issues and found a couple of other 2 bolts where 6 would be better scenarios which are now also rectified!
Fri Jan 15, 2021 12:40 pm
thanks for this I will check my one I thought you were saying the pedal and not the frame was broken
when did my brake-upgrade http://www.gtmdrivers.com/forum/brake-u ... t3742.html
I found that It was only attached with one bolt on one side I can't remember if I fixed it with two
I can't think I would have left it with one
Mon Jan 18, 2021 1:00 pm
