It is currently Sun Apr 19, 2026 1:32 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
How to modify your rubber cones. Spring Rates
Post Re: How to modify your rubber cones. Spring Rates
Yes, I joined about 5 months ago but didn't get a manual. I've never had a newsletter either because there were none left at the time - have there been any recently?
Wed Oct 15, 2008 9:34 pm
Dino wrote:
ibrooks wrote:
.,..I did some work on a set for a friend where I turned the flange off a set of Mini cones and made it's rear face flat. I then cut the step a little deeper on a set af cheap "hi-lo's" so that the Mini flange would fit over the "hi-lo". This gave him the adjustment whilst retaining the curved surface of the original Mini item.
Iain
Interesting, So was there a noticable change?
I had a set of rear trumpets with a larger than usual flange a while ago (possibly off a van?)
Unfortunatly I didn't do any back to back testing, but the Mini they went in certainly handles nicely.
No idea - I've never driven the car in question. The trumpets looked nice and the theory seemed sound so I spent an hour or so on the lathe in return for a mint grille badge for the front of my Clubman.
That's the beasty though - the general opinion at the club is that it's very.......... erm..... very........ Brent
Iain
Wed Oct 15, 2008 10:19 pm
I've been in the club for ten years and there's never been any free manual's.
What would a Libra/Spyder/K3 owner want with a Coupe manual :?:
When Bob took over the membership sec job , we found these manual's and decided to offer them for sale at £10, so I'll have to have a word with Bob, £5 that's a bargain :o
Bob S.
Bob S.
GTMOC Secretary
Wed Oct 15, 2008 10:55 pm
Hi there,
The original rubber cones which GTM had machined are rotten. Can I just fit a normal set for now or is the ride completely unbearable?
I assume the machined cones are only for the front, standard cones in the back.
Mon Feb 23, 2009 1:18 pm
When I first got my Coupe the rubbers were of the standard mini type i.e. undrilled, however I never drove it so can not comment on drivability.
Mon Feb 23, 2009 6:04 pm
GTM-Marty wrote:
Hi there,
The rear cones can be standard as the weight is similar but standard cones at the front will be far too stiff. I doubt if you could even get the ride height down to a reasonable level.
Tue Feb 24, 2009 12:06 am
Many years ago -- mid 70's -- I remember seeing a technical paper on Mini rubber springs showing rising rate curves and the effect of the trumpet top section. I though I had it in my old uni junk but I can't find it. I think is was attributed to Dunlop who made the springs under liesence from Moulton. May be availabe in some univeristy library somewhere -- possibly the I Mech E? I did a short search on the patent office website for the original patent with no luck -- I probably couldn't define my search well enough -- latest Moulton patents are all on bikes.
Has anyone tried a couple of Smootha Ride springs on the front or for the more extreme amongst us MiniSpares hard racing springs on the back?
Mon Mar 02, 2009 10:51 am
