It is currently Sun Apr 19, 2026 1:31 am
Brake switch
Post Brake switch
Can anyone remember how the brake switch was fitted to the early minis (i.e. on front right brake hose union), I need to put one on my Coupe kitcar (same setup) but can't remember what was needed in order to do so. At the moment there is a double union with a banjo bolt through the centre attaching onto the front RHS brake pipe, is it a case of removing the banjo bolt and replacing it with a switch or is there a special piece???
Mon Jun 08, 2009 10:17 am
Post Re: Brake switch
Andy wrote:
...is it a case of removing the banjo bolt and replacing it with a switch ...
Yes, that's all you need to do.
The switch has a banjo bolt mounting on it.
Mon Jun 08, 2009 10:43 am
Yes.
There is a 180 degree double banjo fitting on the offside flexible hose and the brake light switch takes the place of the banjo bolt
BUT
to be honest I never liked it there. It gets exposed to all the road muck and the terminals corrode. I always mount mine up near the master cylinder by plumbing in an extra 3 way union.
Mon Jun 08, 2009 3:23 pm
Isn't a mechanical switch on the brake pedal a better design? I always thought that the pressure switches were a bit "Iffy". :shock:
Mon Jun 08, 2009 3:29 pm
Thanks guys, I thought that was the case, I too thought of moving it up out of the way and I think I will continue to do so, the switch on the pedal box is fine but mine is an aftermarket one and I don't want to go refabricating stuff as its been powdercoated already. Thanks again.
Mon Jun 08, 2009 5:22 pm
I found a photo of mine.
You can just see the switch and the union in front of the brake master cylinder.
Mon Jun 08, 2009 7:24 pm
