bwd1958
Joined: Sun Jul 28, 2013 9:32 am Posts: 7 Location: Edzell GTM: Cox/Coupe
 Sliding windows
I had decided that one of the first things to do on my coupe was to sort the rattling side windows so I ordered two complete side window kits from mini spares. They turned up today so I unpacked them and tried the various pieces against the car and found that the two bottom seals were short and not only are the two chrome/stainless steel strips short but also the window catch locking holes appear to be in the wrong place! Have I ordered the wrong parts or am I being a bit dim but it does seem that the coupes doors are longer than a minis.
Cheers Bruce.
| Tue Jul 11, 2017 10:48 pm |
kano nordie
 Re: Sliding windows
Coupe windows are longer than mini, if my memory is correct only the window catches from a mini are usable my old Cox had sliding windows, the Coupe I'm building now has a one piece window with a circular vent from Car Builder Solutions fitted John
| Wed Jul 12, 2017 6:12 am |
Sven
 Re: Sliding windows
I seem to remember when i done my coupe (back in the early 90's) that i bought long strips & cut them to size. But don't know if you can still buy them like that
| Wed Jul 12, 2017 7:39 am |
grizzler73
 Re: Sliding windows
The frame of the Cox/Coupe is a channel specially formed for the car, it is not a Mini Door frame cut off and bolted on to the Coupe door. you will then need to get some plastic and cut new windows using the old ones as a template. This is what you need. https://www.carbuildersolutions.com/uk/ ... -per-metre
| Wed Jul 12, 2017 11:19 am |
rossabitz
 Re: Sliding windows
I know Derek Hambly has the glass in stock. I think I still have the stainless steel channels.
| Wed Jul 12, 2017 2:29 pm |
grizzler73
 Re: Sliding windows
Is the channel for the slider rubber to sit in not just the one off a mini? Cheers simon
| Wed Jul 12, 2017 4:21 pm |
bwd1958
 Re: Sliding windows
Hi folks thanks for all your replies. My window glass is in good condition it was the seals and chrome locking strips that I tried to replace with ones from mini spares but the coupe windows are about 25mm longer. Rossabitz when would be the best time to phone you? Cheers Bruce.
| Wed Jul 12, 2017 4:44 pm |
derek hambly
Joined: Sat Nov 09, 2013 8:17 pm Posts: 55 GTM: Cox/Coupe
 Re: Sliding windows
Hi there, I have a batch of undrilled window channels in satin finish stainless steel. Derek Hambly
| Fri Jul 14, 2017 7:00 pm |
Steve Shield
 Re: Sliding windows
That's a very sprawnsy chair you've got there Derek
| Sat Jul 15, 2017 8:17 am |
kano nordie
 Re: Sliding windows
A very sexy squashed oval exhaust outlet
| Sat Jul 15, 2017 10:04 am |
