It is currently Thu Oct 22, 2026 8:20 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
front indicators
Post front indicators
hi people any one got any ideas or pictures of some decent front indicators to use on the coupes :D
Thu Nov 29, 2012 9:50 pm
Post Re: front indicators
I used Wipac NAS spec land rover units as I did on the rear.
Thu Nov 29, 2012 10:46 pm
hi mr mac did you fit them quite close to the radiator opening so they sit flatter
Thu Nov 29, 2012 10:55 pm
No, directly under the headlights. They fit fine, the curviture of the body is no problem at this point. I'll take some pics this weekend.
Fri Nov 30, 2012 12:12 am
I am looking for the same thing, as the ones I have on the front now are some Toyota ones that do not fit the curve and are looking pretty tatty. So now looking for other options.. for our rules here they need to be combination of parking lamp and turn signal.. are the Wipac ones dual filament?
MiniMike in Victoria
1989 GTM Coupe - SOLD
1989 Mini 30 VTEC powered
Fri Nov 30, 2012 1:09 am
Nissan Micra K11 side ones are nice and small.
Also available in White/clear if you look
I was looking at Fiat Punto ones also
Fri Nov 30, 2012 1:10 pm
I used the normal Mini ones but I recessed them slightly.
Fri Nov 30, 2012 7:43 pm
thanks for the replys guys its a real help ,ken555 is that 501 bulb if so how does that work being a 5w bulb or is there some thing else ive missed :oops:
Fri Nov 30, 2012 9:02 pm
gtmdriver, how far did you recess the lights?
ken555 - are the Nissan Micras ones dual filament?
Thanks in advance!
Fri Nov 30, 2012 9:32 pm
If you want dual filament suggest you buy the indicator front half and the brake light bulb holder.
http://www.ebay.co.uk/itm/WIPAC-NAS-Stop-Tail-light-LandRover-Defender-90-Td5-NEW-/390504681698?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aebe490e2
With this
http://www.ebay.co.uk/itm/WIPAC-NAS-Indicator-light-lamp-LandRover-Defender-90-/390457390424?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae912f558
The bulb holder are interchangeable.
Fri Nov 30, 2012 9:35 pm
Yes its a 5w bulb, I modified an electronic relay to flash at the required speed.
MOT just checks for an indicator, not how bright.
Afraid not, but you could wire something up I would guess. My Headlights are "angel eyes" type so no sidelight lights required.
Fri Nov 30, 2012 9:40 pm
Yes, I can fit a dual socket behind although a lot of the newer light housings are plastic molded sockets so not the easiest, as need to keep it watertight from the rear... another option is use some relays to make it work for both park and signal?
Good idea Mr. Mac! That place does not ship outside the UK.. but I may be able to find them elsewhere..I would prefer the 70mm size though..
Fri Nov 30, 2012 10:33 pm
Just search eBay for NAS Wipac and you will find loads of people selling them. Failing that try any of the aftermarket land rover online shops.
If you want me to buy them and ship them let me know - not a problem although it might cost a bit in postage.
Fri Nov 30, 2012 11:05 pm
Thanks in advance!
I recessed them so that they were square across the car but the outer edge was flush with the body panel.
Sat Dec 01, 2012 6:00 pm
A subtle but effective way to mount them.. thanks.. I have a few options to think about..I think maybe a trip to the breakers to poke around might help sort something out..
Sat Dec 01, 2012 6:40 pm
Users browsing this forum: Google [Bot] and 3 guests
