It is currently Sun Apr 28, 2024 9:16 pm
Post new topic Reply to topic  [ 92 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
Paul's libra
Post Paul's libra
I have just picked up a libra today it needs a complete dismantle and rebuild
I'm going to need a new set of seats for the inside
And the red gel coat has faded a little bit :lol: not quite
sure what I'm going to be doing with this yet
Thu Sep 30, 2021 10:40 pm
Post Re: Paul's libra
At least it seems to all be there. I guess the fading might polish out depending on how deep it goes into the gel coat. Got to be worth a go with a polisher and some farecla G3 on a foam pad to see how deep it goes. Good luck and keep the progress pics coming
Fri Oct 01, 2021 9:43 am
I have been and taken some photos of the car to day and it looks like i will have a lot of work to do
Image Image Image Image Image Image Image
Image Image
Fri Oct 01, 2021 10:50 pm
Looking forward to seeing the transformation. It'll be great to see another Libra back on the road.
Fri Oct 01, 2021 11:36 pm
If it's an older car then the gelcoat should be good quality and be able to be polished back to proper colour.
Make sure to add yourself to the Libra list on here.
Sat Oct 02, 2021 11:39 am
I have started to take it apart I think it will take a lot of work and new parts
Sun Oct 03, 2021 7:27 pm
I have taken the door cards off the doors so I can remove the wing mirrors and the door handles and also the locks
so I can start to polish the car and see what colour it is
I do not know if I'm going to keep this grey colour or change it for something different
I'm going to recover the door cards it's going to be much easier than doing it on my K3 on the libra they are just flat
I might change the colour to Black I don't know how this will look but this is going to be a long way off in the future as I've got a lot more jobs
Mon Oct 04, 2021 1:16 pm
I have started to polish the car it may seem crazy to start here but this will tell me if I need to spray it or not
I have given the car the first go over and its starting to look much better
Image Image
Image Image
Sun Oct 10, 2021 12:41 pm
Wow! That's impressive. What did you use in terms of pads/compound/polish?
Sun Oct 10, 2021 3:33 pm
This is what I have used
https://www.ecfibreglasssupplies.co.uk/ ... ound-32-kg
I have only done one round i have to go over it a again and then polish
Sun Oct 10, 2021 6:50 pm
That is looking promising.
Sun Oct 10, 2021 8:59 pm
I have taken more parts of the car for some reason one of the light plugs was in a plastic bag I don't think it would have worked like that :?
the indicators have lost their colour and all the screws are just rust
Image Image Image
The hinge assembly is not working properly I think there was more rust than hinge
sidewinder is making me a new set all shiny :D :D :D
Image Image
Thu Oct 14, 2021 9:59 am
Image Image Image
why is there a hazard switch in the dash when there is one in the column ( this is not in the manual )
I have been taken more parts from the car
Sun Oct 17, 2021 3:37 pm
Already looking so much better
Mon Oct 18, 2021 6:12 am
Re. the hazard switch....it appears that whoever built your car has used the early Metro column and stalks, which incorporates the hazard switch on top of the column cowling (I'm assuming it doesn't do anything?).
I can't recall where I found the following info but it explains what changed and when:
"1980 Austin Metro through to 1995 Rover Metro including all MG Metro's all use the same steering wheel fitment. All these Metro's have the horn button at the end of the indicator stalk on the left and the hazard switch on top of the column cowling. It features a thick steering column with a top lug for indicator cancellation, which is 18.5mm, 48 splines. Momo boss = MC0250.
The mk4 around 1995 to end of production Rover 100 uses a totally different steering wheel fitment.  Believed the steering column was completely changed to give the option to fit a steering wheel with an airbag from other Rover models, such as 214 and 414 and some Land Rovers, instead of making a Rover 100 only item. The column is of smaller 15mm dia with 29 splines and a 19mm nut to hold the steering wheel on. Momo boss = MC4905"
So, if you wanted to do away with the column hazard switch and swop to the much nicer stalks you would have to change the column as well.
Mon Oct 18, 2021 12:36 pm
