It is currently Sun Oct 25, 2026 3:40 pm
Metro Gear Linkage Bracket
Post Metro Gear Linkage Bracket
There is a bracket which mounts to the subframe of the Metro to which the gear selector rods attach (3x 10mm bolts), this then swivels the movement to select the gears. Mine is so badly worn making gear selection nearly impossible, I can never see this mechanism being great but it's undrivable in its current state, even after taking the play out of the rod linkage.
Sat Mar 21, 2020 6:01 pm
Post Re: Metro Gear Linkage Bracket
Hi, Have you tried Rimmer Bros? See https://rimmerbros.com/Item--i-GRID000723 Is it Part 32 in the Diagram you need as it looks like they can get hold of it. Best of luck Howard W
Sun Mar 22, 2020 12:16 pm
Thanks Howard, it's actually https://rimmerbros.com/Item--i-UKW10004 which I think has all the play in it, I was sort of hoping that somebody who had gone Metro to MGF might have one lying around, but possibly they just binned it with the rest of the subframe. Alan..
Mon Mar 23, 2020 2:14 pm
Looking for 2 gear rods from gear box to gear stick can someone help me we’re to go with this
Sun Jun 05, 2022 10:54 pm
Sorry I have only just seen this post but I do have some gear rods and probably the linkage too!
Tue Aug 02, 2022 4:19 pm
