It is currently Fri Nov 06, 2026 12:59 am
Libra Clutch
Post Libra Clutch
I have a hydraulic clutch on my Libra but it is rather heavy both cylinders are standard MGF items which has a very light clutch any ideas.
Fri Mar 05, 2010 12:02 am
Post Re: Libra Clutch
You could try a larger pipe. Sometimes the restriction of the pipe can cause drag.
A pain of a job to do though I'd guess. :roll:
Fri Mar 05, 2010 9:01 am
The cause will be the pedal ratio.
MGF will be 5:1 or maybe even 6:1. The Libra is nearer 3:1.
Fri Mar 05, 2010 10:22 am
Does that mean you'd need a different cylinder size then?
Fri Mar 05, 2010 10:24 am
Don't know Tim, I guess that might work if you could get it to fit. All the Libra I know have the same set up and most complain more about the brake pedal than the clutch.
I did look at changing the pedal box. Looking is as far as I have got so far :lol:
Fri Mar 05, 2010 6:11 pm
Another problem I have come across [not my car though] with the clutch is the slave cylinder bracket bending when the clutch pedal is depressed,[making it difficult to change gear] could this be linked :?:
Bob S.
Bob S.
GTMOC Secretary
Fri Mar 05, 2010 6:42 pm
I fitted the Elise parts bracket that bolts through the slave mount to the gearbox and takes the flex out.
It doesn't make the pedal any lighter but does make the action better.
I also modded the pedal to give more travel.
Sat Mar 06, 2010 11:59 am
Mines fine, are you just being picky :P
Sun Mar 07, 2010 9:27 pm
