It is currently Thu Nov 19, 2026 4:06 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Libra rear suspension
Post Re: Libra rear suspension
Hi Jimbob
Apologies for not approving your post earlier, seems to have slipped by us.
Green is the Peugeot tie rod end, part no that I have is TA977.
Blue is Metro , Part no that I have is GSJ 733
Yellow, part no that I have is TC439.
Bob.
Bob S.
GTMOC Secretary
Wed Aug 17, 2016 2:41 pm
Hi Jim, welcome to the forum. The Libra is a great car isn't it :D
I'm sure you've had this answered elsewhere as well but the yellow joint on your diagram is definately a Rover Metro / 100 front lower ball joint (std car not GTA / GTI).
Also, the Peugeot track rod fits the upper suspension arm nearest the bulkhead with the metro part nearest the hub.
Incidentally, not sure if you've bought your joints yet but cheapest I've found has been skscarparts.co.uk - I'm calling in there tomorrow to buy joints to refurb my rear suspension (same as yours) and I'm hoping for a bit of discount! :D
Wed Aug 17, 2016 4:10 pm
Sanz - sounds like an easy handling gain you've had there......result :D
Wed Aug 17, 2016 4:11 pm
Can anyone confirm that metro or mgf outer CVs can be used as I need to order a couple
Wed Aug 17, 2016 5:13 pm
metro and mgf non abs cv joints are listed as same part number abs ones maybe worth getting if you think you will need speed sensor in future for any reason
Wed Aug 17, 2016 10:36 pm
Thu Aug 18, 2016 9:28 am
re awakening an old thread. Can't believe it was back in 2016 but I'd bought 8 of the FAI land rover track rod ends but had only fitted the two on the one arm that was moving badly. I finally got around to replacing the other six this week. After doing so I noticed that the arm I'd done back in 2016 now has quite a bit of movement again so it seems 5 years of road use (around 15,000 miles) and 13 track days (mainly on slicks) is enough to wear out the the FAI ball joints on the arm that takes all the load on most UK clockwise tracks - the N/S lower. I've ordered another two so I'll then have a full set of brand new joints. I'll also do the lower one on the upright whilst the arm is off the car.
Of the joints that I removed from the other arms, most actually seemed okay. Two of the six had detectable play but the other four probably could have stayed on.
Fri Apr 02, 2021 8:43 am
