It is currently Wed Jun 10, 2026 8:58 pm
[ 4 posts ] |
Alex Gibson (AXLE)
 mini pedal box
Is there any difference between a mini servo assisted pedal box and a non servo pedal box and if so how can you tell the difference?
Cheers, Alex
| Mon Nov 08, 2010 8:08 pm |
 Re: mini pedal box
Not much difference from memory. on the actual in car side of things, might be worth checking the spacing of the studs
| Mon Nov 08, 2010 8:26 pm |
Dino
 Re: mini pedal box
If you're talking about the early separate type as fitted to the S then no difference. The later ones with integral servo, obviously the bit under the bonnet is different, but the pedals themselves are pretty much the same.
| Mon Nov 08, 2010 11:35 pm |
ibrooks
 Re: mini pedal box
The pedal "box" itself is no different. The brake pedal is different - where you would have the clevis pin on a non-servo car it has a pushrod riveted to the pedal. The plate that fits on the outside of the bulkhead is different (it doesn't have the continuous lip all arount turning it into a drip tray for brake fluid). Then of course there is a frame with a pivot linkage and the servo and master cylinder itself.
Iain
| Tue Nov 09, 2010 11:33 am |
[ 4 posts ] |
