It is currently Wed Jun 10, 2026 9:07 pm
mini pedal box
Post mini pedal box
Is there any difference between a mini servo assisted pedal box and a non servo pedal box and if so how can you tell the difference?
Cheers, Alex
(Gulf) GTM Coupe
Mon Nov 08, 2010 8:08 pm
Post Re: mini pedal box
Not much difference from memory. on the actual in car side of things, might be worth checking the spacing of the studs
Mon Nov 08, 2010 8:26 pm
If you're talking about the early separate type as fitted to the S then no difference.
The later ones with integral servo, obviously the bit under the bonnet is different, but the pedals themselves are pretty much the same.
Mon Nov 08, 2010 11:35 pm
The pedal "box" itself is no different. The brake pedal is different - where you would have the clevis pin on a non-servo car it has a pushrod riveted to the pedal. The plate that fits on the outside of the bulkhead is different (it doesn't have the continuous lip all arount turning it into a drip tray for brake fluid). Then of course there is a frame with a pivot linkage and the servo and master cylinder itself.
Iain
Tue Nov 09, 2010 11:33 am
