flippspeed
Joined: Tue May 01, 2012 8:40 pm Posts: 190 Location: hampshire GTM: Cox/Coupe
 Re: r 1 coupe
good weekend, few more mods done but got there in the end, motors in now happy days
| Sun May 19, 2013 7:36 pm |
mayoturbo
 Re: r 1 coupe
Looks great. Will be good fun! wonder how light it will be in the end
| Mon May 20, 2013 12:26 pm |
flippspeed
 Re: r 1 coupe
hi mayoturbo should be nice and light, I can pick the rear up at the mow quite easy
| Mon May 20, 2013 8:59 pm |
David Large
 Re: r 1 coupe
I have a stripped out track car, a motorbike engined coupe with a space framed back end and it weighs a depressingly heavy 650kg. I compete against cars that weigh 350-400kg with similar motorbike engines. Hence I added a turbocharger which certainly evened things up dramatically, until an exhaust valve broke following, I guess, a collision between the valve and the piston! I am currently in the early stages of rebuilding the engine with forged pistons and Carrillo con rods. This set up should give me the best part of 300bhp - hopefully reliably. Regards David
| Mon May 20, 2013 10:16 pm |
David Large
 Re: r 1 coupe
flippspeed wrote: hi mayoturbo should be nice and light, I can pick the rear up at the mow quite easy  Are you adjusting the wheelbase of the car ie relocating the rear wheels further towards the back of the car to accomodate the engine, diff and connecting chain or are you running a different sort of differential arrangement? David
| Tue May 21, 2013 6:54 am |
flippspeed
 Re: r 1 coupe
hi david the wheel base is standard was going to adjust it but got around the problem
| Tue May 21, 2013 6:00 pm |
David Large
 Re: r 1 coupe
Ah, well how did you do that please?
David
| Tue May 21, 2013 7:05 pm |
flippspeed
 Re: r 1 coupe
hi david there you go
| Sat May 25, 2013 8:21 pm |
David Large
 Re: r 1 coupe
Wow, can I come and look at that please David
| Sat May 25, 2013 8:59 pm |
flippspeed
 Re: r 1 coupe
bit far to come for just a look
| Sun May 26, 2013 8:37 pm |
David Large
 Re: r 1 coupe
On 19th June we are going to catch an overnight ferry from Portsmouth which sails at 11/00pm - we are going to Le Mans - don't know where you are but if you are in Hampshire we must be travelling in the right direction? I would really like to look at this set up - it may solve a potential problem for me.
regards
David
| Mon May 27, 2013 7:38 am |
flippspeed
 Re: r 1 coupe
hi david let me know nearer to the time ,cant see a problem cheers
| Mon May 27, 2013 11:51 am |
David Large
 Re: r 1 coupe
Thanks, I will be in touch.
David
| Mon May 27, 2013 5:03 pm |
flippspeed
 Re: r 1 coupe
few more bits added
| Tue Jun 04, 2013 9:20 pm |
flippspeed
 Re: r 1 coupe
little more work done Saturday getting there slowly
| Sun Jun 16, 2013 8:23 am |
