It is currently Fri Jun 05, 2026 6:52 pm
Post new topic Reply to topic  [ 335 posts ]  Go to page 1, 2, 3, 4, 5 ... 23  Next
Paul's k3
Post Paul's k3
hi all this is my first kit car. after looking for one for some time I now own a very nice k3 rossa
Thu Sep 12, 2013 9:41 pm
Post Re: Paul's k3
Nice car 8) Good to get one that's been well restored and ready to go. Enjoy :D
Thu Sep 12, 2013 9:54 pm
Post Re: Paul's k3
thanks, RaymondH
I have seen that the windows do not open the same the n/s does not close right to the top and the o/s one does not go all the way down
I think this will be the first thing I will have a look at there are some small things I would like to do and some that need to be done and
one big thing is to put a 1.8 vvc engine in the car
Thu Sep 12, 2013 10:07 pm
Post Re: Paul's k3
when taken off the door panels I found that the Door Interior handle surround are two different Colours I would like to see if I can find a black one
Sat Sep 14, 2013 9:19 pm
Post Re: Paul's k3
I searched for black ones for ages and in the end I painted my beigey ones (yuk!) with Halfords bumper paint, using their preparation cleaner first. It was expensive but very successful and I've since painted other parts including a steering column surround so perhaps not so expensive after all because it made a big difference to the interior.
Sat Sep 14, 2013 11:05 pm
Post Re: Paul's k3
My wife had a beigey metro and yes yuk. thanks, I would not have thought of painting it with bumper paint
I had a look and yes it is expensive I have been on eBay and found one they won't 16 pounds for one.
it would not be much more than painting it so I think I might get one from eBay
Sun Sep 15, 2013 4:27 pm
Post Re: Paul's k3
Just make sure that it is black. I once bought one that looked black in the photo but when it arrived it wasn't....
Sun Sep 15, 2013 9:23 pm
Post Re: Paul's k3
hi, I have spent time on the car this weekend and fixed the windows. I had to adjust the stops for the motors to get the windows to stop at the top and bottom.
I have also got a new black Door Interior Handle Surround
File comment: Window stop
Sun Sep 22, 2013 7:43 pm
Post Re: Paul's k3
I have got the windows working ok.
I'm now looking at the wiring plugs I'm going to change them
with some Sealed Waterproof Connector
Sat Sep 28, 2013 8:50 pm
Post Re: Paul's k3
hi all
I have not done much to my car
I'm going to fit a start button which I got from eBay but I'm going to use an Arduino with a relay shield to control the starting of the engine no need for a key.
the plain is to use the keyfob which will open the doors disarm the alarm and activate the button which will turn on the ignition then you push the button again to start the car.
when the car is running you will use the button to stop the car.
this way over the top just to start the car but its a project
Tue Dec 24, 2013 10:39 am
Post Re: Paul's k3
the sun is out and I have some time to tinker with my car and I'm inside but I have some code done for my starter switch
I just need to find out some things from the car alarm also an input from the engine to say the car is running
still loads to do to get it to work
I have put the program in a pdf file
the start button.pdf [35.15 KiB]
Downloaded 1092 times
Sun Mar 09, 2014 1:46 pm
Post Re: Paul's k3
:D
Yes the sun is out!
Good to hear your making some progress, I will have to believe you when you say that is the program. This is something I want to try and do in the future, play with an arduino but at the minute its a bit Greek to me :lol:
Sun Mar 09, 2014 2:42 pm
Post Re: Paul's k3
has anyone fitted one of them ELECTRIC BOOT RELEASE if you have can you help
how did you fit it?
I'm just trying to find the best place to fit it
Sun Mar 16, 2014 6:44 pm
Post Re: Paul's k3
I was making a new part for the car and I moved the 5as car alarm. and 2 wires fell of the second plug well I say plug it did not have one.
so spent hours looking at electrical diagrams to find out where they go. then I found the right plug on the web
all I have to do is find the right pins and put it all back
File comment: 5as
File comment: photo (1)
File comment: photo (2)
File comment: photo (3)
Wed Apr 16, 2014 12:35 pm
Post Re: Paul's k3
the dash of the car is all back together I have made a new center part for the dash
Sat May 17, 2014 10:45 pm
