It is currently Sat Nov 21, 2026 11:12 pm
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 23  Next
Paul's k3
Post Re: Paul's k3
I have taken out the front tub
I have given it some paint and a bit of carpet which I got from Stoneleigh kitcar show
it had this thick plastic backing on the carpet.
I found very hard to get to lay flat inside the tub
so had to heat it up with a heat gun and bend it around the corners
Tue May 20, 2014 11:17 pm
Post Re: Paul's k3
when I removed the tub I found that the hose clip's where all rusted
I have put some new stainless steel clips on the pipes and have put the tub back in
Thu May 29, 2014 12:41 pm
Post Re: Paul's k3
I have started to fix the boot
I found the hole in the boot was too big for the pin and the top hat
it just fell in the hole
at my work, they was changing some bronze bushes that looked like they would fit
20 mm outside and 10mm inside would do the trick
I have fiberglassed them in the hole
all looks like it will work
I have now found that the exhaust blows at the joint
when I tried to do the clamp up it broke next thing to fix
Sat Jun 21, 2014 12:28 am
Post Re: Paul's k3
here are the clamps witch was on the exhaust pipes not all that strong
I have fixed the exhaust with 2 new stainless steel clamps
much stronger job than the old ones
Wed Jul 09, 2014 1:05 pm
Post Re: Paul's k3
I have started to make a new fuel tank it needs a bit more work
yes its made of wood
thanks, PEEPS for the drawings of the tank and component parts
Tue Jul 15, 2014 6:31 pm
Post Re: Paul's k3
I have removed 100m from the MGF fuel pump guide
legs to make it fit in my tank.
(The mgf tank is a plastic
molded tank)
Thu Jul 17, 2014 9:16 pm
Post Re: Paul's k3
catsam wrote:
i have removed 100m from the MGF fuel pump guide
How big is the MGF tank? :lol: :roll:
Fri Jul 18, 2014 8:22 am
Post Re: Paul's k3
Ok it was some time before I saw it sorry
:oops: :oops: :cry:
I cut 100mm of the pump
Fri Jul 18, 2014 11:50 am
Post Re: Paul's k3
The fuel tank is placed centrally on the shelf which allows the roll over bar to bolt through the tub to the front subframe mounts, through the tub to the torque tube mounts and through the floor.
I will try to put an image on but don't hold your breath!
Sun Jul 20, 2014 6:48 pm
Post Re: Paul's k3
Pump side
Sun Jul 20, 2014 6:51 pm
Post Re: Paul's k3
Thanks that is nice work
I can see now see why my tank would not fit
My tank will not fit in the middle as the tub has a big curved section in the way
and I had put the tank in upside down :roll: :roll:
Sun Jul 20, 2014 9:24 pm
Post Re: Paul's k3
Fits like a glove on a chickens lip!! :D
Tue Jul 22, 2014 12:41 pm
Post Re: Paul's k3
This is my roll over bar. Not a full cage by any means but enough to stiffen up the rear bulkhead and offer me a very strong mount for a three point harness. The bottom plates are bolted on after fastening to the subframe front mounts using welded on studs, (saves needing two people to hold spanners!)
Tue Jul 22, 2014 1:07 pm
Post Re: Paul's k3
hi peeps I can see what you mean about cutting this out of the tank it does not lay flat
Thu Sep 04, 2014 12:40 am
Post Re: Paul's k3
Yes it burst my bubble of an easy life, mine went very oval resulting in it being useless so i has to make one from scratch.
Thu Sep 04, 2014 1:37 pm
