catsam
Joined: Thu Jun 27, 2013 11:32 pm Posts: 492 Location: Norfolk GTM: Libra
Re: Paul's k3
I have taken out the front tub I have given it some paint and a bit of carpet which I got from Stoneleigh kitcar show it had this thick plastic backing on the carpet. I found very hard to get to lay flat inside the tub so had to heat it up with a heat gun and bend it around the corners
Tue May 20, 2014 11:17 pm |
catsam
Re: Paul's k3
when I removed the tub I found that the hose clip's where all rusted I have put some new stainless steel clips on the pipes and have put the tub back in
Thu May 29, 2014 12:41 pm |
catsam
Re: Paul's k3
I have started to fix the boot I found the hole in the boot was too big for the pin and the top hat it just fell in the hole at my work, they was changing some bronze bushes that looked like they would fit 20 mm outside and 10mm inside would do the trick I have fiberglassed them in the hole all looks like it will work I have now found that the exhaust blows at the joint when I tried to do the clamp up it broke next thing to fix
Sat Jun 21, 2014 12:28 am |
catsam
Re: Paul's k3
here are the clamps witch was on the exhaust pipes not all that strong I have fixed the exhaust with 2 new stainless steel clamps much stronger job than the old ones
Wed Jul 09, 2014 1:05 pm |
catsam
Re: Paul's k3
I have started to make a new fuel tank it needs a bit more work yes its made of wood thanks, PEEPS for the drawings of the tank and component parts
Tue Jul 15, 2014 6:31 pm |
catsam
Re: Paul's k3
I have removed 100m from the MGF fuel pump guide legs to make it fit in my tank. (The mgf tank is a plastic molded tank)
Thu Jul 17, 2014 9:16 pm |
Tim Rowe (1130)
Re: Paul's k3
catsam wrote: i have removed 100m from the MGF fuel pump guide legs to make it fit in my tank. How big is the MGF tank?
_________________ Tim Rowe
Fri Jul 18, 2014 8:22 am |
catsam
Re: Paul's k3
Ok it was some time before I saw it sorry I cut 100mm of the pump
Fri Jul 18, 2014 11:50 am |
PEEPS
Re: Paul's k3
The fuel tank is placed centrally on the shelf which allows the roll over bar to bolt through the tub to the front subframe mounts, through the tub to the torque tube mounts and through the floor. I will try to put an image on but don't hold your breath!
Sun Jul 20, 2014 6:48 pm |
PEEPS
Re: Paul's k3
Pump side
Sun Jul 20, 2014 6:51 pm |
catsam
Re: Paul's k3
Thanks that is nice work I can see now see why my tank would not fit My tank will not fit in the middle as the tub has a big curved section in the way and I had put the tank in upside down
Sun Jul 20, 2014 9:24 pm |
PEEPS
Re: Paul's k3
Fits like a glove on a chickens lip!!
Tue Jul 22, 2014 12:41 pm |
PEEPS
Re: Paul's k3
This is my roll over bar. Not a full cage by any means but enough to stiffen up the rear bulkhead and offer me a very strong mount for a three point harness. The bottom plates are bolted on after fastening to the subframe front mounts using welded on studs, (saves needing two people to hold spanners!)
Tue Jul 22, 2014 1:07 pm |
catsam
Re: Paul's k3
hi peeps I can see what you mean about cutting this out of the tank it does not lay flat
Thu Sep 04, 2014 12:40 am |
PEEPS
Re: Paul's k3
Yes it burst my bubble of an easy life, mine went very oval resulting in it being useless so i has to make one from scratch. Attachment:
Thu Sep 04, 2014 1:37 pm |
