kano nordie
 Re: Rear wheels
Hi Harold, I think that will do the job for you at 1900c  when it is heated it should loosen and be able to remove, then grease everything and put it back. John
| Thu Mar 17, 2016 12:37 pm |
Yoda74
 Re: Rear wheels
John, My plan was not to take it off and refurbish it, but maybe that's the only good way to go. Are new toe-in-adjusting-bars available somewhere if I can't loosen te nuts? And nuts with right- en lefthand thread. I'll try not to burn my car and garage down, I've heard some people do
| Thu Mar 17, 2016 12:51 pm |
kano nordie
 Re: Rear wheels
Some body on here will recommend a company making tie rods with right and left hand threaded ends, I have to make my own here at the ends of the earth and am just sorting out a new rear stear locking system to fix to the lower arm and caliper back plate (could be Plan F) anyway think posative everthing I have heated has come loose  dont burn the car, I lost my 1st Cox GTM in a garage fire
| Thu Mar 17, 2016 1:48 pm |
kano nordie
 Re: Rear wheels
PS Harold, I do have a rear steer locking system which won't be used as it fouled my old Cox exhaust, if you're in the UK for the Stoneleigh kit car show I should be there on the Monday with my Jedi race car. John
| Thu Mar 17, 2016 1:53 pm |
Elansprint
 Re: Rear wheels
John have a look at McGill motorsports in fife they do arrange of standard lengths they are on the web Ian
| Thu Mar 17, 2016 4:17 pm |
kano nordie
 Re: Rear wheels
Hi Ian, Thanks for that, it is for Harold if he spoils his rusted ones trying to get them loose, I would still make my own, 1st because I can and 2nd the problem of getting anything sent to darkest Africa. Cheers John
| Thu Mar 17, 2016 4:25 pm |
 Re: Rear wheels
Yoda74 wrote: Neil,
Do you mean 1-2 mm per wheel, measured from back to front of the rim? (Not tire)
Correct I always measure to the wheel rim Neil
| Thu Mar 17, 2016 4:32 pm |
Ken555
 Re: Rear wheels
This might be handy if needed http://www.trackace.co.uk/manual/conversion%20chart.pdfmm to degree chart for various sized wheels
| Thu Mar 17, 2016 5:55 pm |
Yoda74
 Re: Rear wheels
Thans guys. @ John: you got my hint about setting the car on fire Hopefully I Will be able to loosen the nuts. The soldering- torch is on it's way Cleaning and Coppergrease will hopefully make it as new... The chance that I will be at stoneleigh is not very large. I Will check mcGills too. Any idea what kind of thread the rod has? Can I just keep on turning the rod untill it comes out? How long is the thread?
| Thu Mar 17, 2016 7:44 pm |
kano nordie
 Re: Rear wheels
If the tie rod is a British Leyland part it will be a UNF thread probably 1/2", whenever I make something I usually go metric as its so much easier to find taps and bolts, etc, once it starts to move keep going until its out, probably 1-1/2" long Don't worry I got the hint, that was a very sad day  I will dig out and post pictures after the fire John
| Thu Mar 17, 2016 8:48 pm |
kano nordie
 Re: Rear wheels
Cremated GTML 129 1969 Cox GTM all Copper S engine and brakes 1426cc on 45 Webber
| Fri Mar 18, 2016 7:24 am |
kano nordie
 Re: Rear wheels
kano nordie wrote: Cremated GTML 129 1969 Cox GTM all Copper S engine and brakes 1426cc on 45 Webber The world was almost upside down that day
| Fri Mar 18, 2016 7:26 am |
Yoda74
 Re: Rear wheels
Holy smokes, what a sad day
| Fri Mar 18, 2016 7:51 am |
 Re: Rear wheels
That looks like quite a project. How is the rebuild going?
| Fri Mar 18, 2016 8:20 am |
kano nordie
 Re: Rear wheels
The fire was in 1989, very slowly
| Fri Mar 18, 2016 8:27 am |
