It is currently Sun Nov 08, 2026 12:05 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
Rear wheels
Post Re: Rear wheels
Hi Harold, I think that will do the job for you at 1900c :wink: when it is heated it should loosen and be able to remove, then grease everything and put it back.
Thu Mar 17, 2016 12:37 pm
John,
My plan was not to take it off and refurbish it, but maybe that's the only good way to go.
Are new toe-in-adjusting-bars available somewhere if I can't loosen te nuts?
And nuts with right- en lefthand thread.
I'll try not to burn my car and garage down, I've heard some people do :?
Thu Mar 17, 2016 12:51 pm
Some body on here will recommend a company making tie rods with right and left hand threaded ends, I have to make my own here at the ends of the earth and am just sorting out a new rear stear locking system to fix to the lower arm and caliper back plate (could be Plan F) anyway think posative everthing I have heated has come loose :mrgreen: dont burn the car, I lost my 1st Cox GTM in a garage fire :oops:
Thu Mar 17, 2016 1:48 pm
PS
Harold,
I do have a rear steer locking system which won't be used as it fouled my old Cox exhaust, if you're in the UK for the Stoneleigh kit car show I should be there on the Monday with my Jedi race car.
Thu Mar 17, 2016 1:53 pm
John have a look at McGill motorsports in fife they do arrange of standard lengths they are on the web
Ian
Thu Mar 17, 2016 4:17 pm
Hi Ian,
Thanks for that, it is for Harold if he spoils his rusted ones trying to get them loose, I would still make my own, 1st because I can and 2nd the problem of getting anything sent to darkest Africa.
Thu Mar 17, 2016 4:25 pm
Yoda74 wrote:
Neil,
Do you mean 1-2 mm per wheel, measured from back to front of the rim? (Not tire)
Correct I always measure to the wheel rim
Thu Mar 17, 2016 4:32 pm
This might be handy if needed
http://www.trackace.co.uk/manual/conversion%20chart.pdf
mm to degree chart for various sized wheels
Thu Mar 17, 2016 5:55 pm
Thans guys.
@ John: you got my hint about setting the car on fire :lol:
Hopefully I Will be able to loosen the nuts.
The soldering- torch is on it's way
Cleaning and Coppergrease will hopefully make it as new...
The chance that I will be at stoneleigh is not very large.
I Will check mcGills too.
Any idea what kind of thread the rod has?
Can I just keep on turning the rod untill it comes out? How long is the thread?
Thu Mar 17, 2016 7:44 pm
If the tie rod is a British Leyland part it will be a UNF thread probably 1/2", whenever I make something I usually go metric as its so much easier to find taps and bolts, etc, once it starts to move keep going until its out, probably 1-1/2" long
Don't worry I got the hint, that was a very sad day :oops: I will dig out and post pictures after the fire :cry:
Thu Mar 17, 2016 8:48 pm
Cremated GTML 129 1969 Cox GTM all Copper S engine and brakes 1426cc on 45 Webber
Fri Mar 18, 2016 7:24 am
The world was almost upside down that day
Fri Mar 18, 2016 7:26 am
Holy smokes, what a sad day
Fri Mar 18, 2016 7:51 am
That looks like quite a project. How is the rebuild going? :wink:
Fri Mar 18, 2016 8:20 am
The fire was in 1989, very slowly :roll:
Fri Mar 18, 2016 8:27 am
