It is currently Tue May 26, 2026 6:15 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
Cumbrian coupe
Post Re: Cumbrian coupe
Ref the clutch return spring -- with judicious use of a hammer you can bend the bracket that fits on the arm so that it sits horizontal under the chassis frame. With a bit of jiggling the spring will still fit and find its way to the other small bracket that fits on the bleed nipple. The spring sits very close to the gaiter and in some cases may rub so a tie wrap round it might avoid it coming off. The spring leverage ratio is reduced a little but I don't think this matters in practice.
Hope this helps.
Tue Feb 28, 2017 10:24 am
Time for an update, not had much time lately due to revision for my GCSE exams. Inspired by Andys 83 coupe (now the LuxSpeed coupe) it was decided to fit a bias pedal box, this also gave me a good opportunity to learn to weld. The front subframe has been fitted, we are trying coil springs all round in place of rubber cones, there are softer springs on the front and more firm springs at the rear.
Pedal heights not finally set.
Wed Jun 07, 2017 7:29 pm
Nice bit of fabrication there. Coming along nicely.
Wed Jun 07, 2017 9:57 pm
I like where this thread is going. Should be a beauty when you're finished. You've fitted the same dampers as I have - they've worked well so far on my car in all conditions. I'd love to try springs instead of rubber cones but don't want to mess with the car too much at the moment as I've finally been enjoying driving it for the last couple of years, after owning it since '98.
Keep it up :D
Thu Jun 08, 2017 5:37 pm
Time for quite a large update! Firstly the gear change has been sand blasted and powder coated and has now been fitted to the car, with some minor reshaping to get it to work smoothly.
A miniature heater has been fitted mounted on aluminium brackets that I created. The holes for the hoses have been moved from the side of the tunnel to the top for convenience.
A Specialist Components 5 port engine management kit has been fitted and is set to give the engine some life! It has a single 50mm throttle body. The wiring harness for this has been fitted, and some of the high pressure hoses have been fitted, along with a fuel pressure regulator on the rear bulkhead. The stainless steel exhaust manifold is also a Specialist Components item and has points to mount Lambda sensors. Unfortunately the shiny exhaust has been wrapped to reduce heat in the engine bay. :(
The injection system was removed in this photo to remove some imperfections inside the inlet manifold.
Thu Oct 19, 2017 9:44 pm
The master cylinders for the bias brake system and clutch have been attached to the pedal box assembly and all brake lines front and rear have been fitted. The front radiator (Vauxhall combo) has been fitted with not much room to spare. The radiator has been rubber mounted on brackets made out of aluminium strip, and the fan on the rear fixed using more metal strip. The inlet and outlet of the radiator is attached to the stainless pipes down the centre of the car using flexible rubber hosing. The radiator also has a useful small bleed valve in case of an airlock.
Thu Oct 19, 2017 9:57 pm
Beautiful job!!!
Libra V6
Hawk AC Ace
TVR 3000M
MG ZTT 180
Skoda Fabia VRS
Thu Oct 26, 2017 12:03 pm
Where does the silencer can go on that exhaust system?
Be ready for some smoke from that exhaust wrap too - I tried some black once and all the black burnt off nearly choking the whole county. The wrap was almost white after a couple of week.
Have to say I'm loving the quality and attention to detail in this build :D
Thu Oct 26, 2017 1:14 pm
What's a silencer? :shock: :lol: :roll:
This build is turning out to be a really well thought out, classy Coupe.
Good job 8)
Fri Oct 27, 2017 9:36 am
The exhaust shown in the photos is just a standard, off-the-shelf exhaust manifold. Once the body has been fitted, we are going to get a custom exhaust made which should end up looking something like Derek Hambly's exhaust in the 'New Coupe Project' thread. I still can't attach any photos, sorry!
Ben
Sun Oct 29, 2017 11:27 am
We have chosen to fit a new alloy fuel tank, this one was made up by concept racing and has a VDO fuel sender and is foam filled. During the designing we changed the small welded on brackets on the original design fuel tank, to use straps instead. The fuel pump and filter are both mounted on the bulkhead. There are outward and return pipes due to the fuel injection system, the rubber hoses attach to two metal fuel lines running down the centre of the car.
Wed Jan 17, 2018 7:20 pm
We have modified the dash support rail to increase strength.
Using CAD (cardboard aided design!) we mocked up a possible dashboard design for the car, this will be cut out of some brushed aluminium sheet.
The speedo is powered by a mini spares electronic speedo adapter and the tacho gets the signal from the ECU. The two smaller digital gauges are for oil pressure, water temperature, fuel level and voltage.
We have also fitted the washer bottle to the front subframe, a 6 fuse fusebox, some relays for the fan, fuel pump and heated screen. Also the horn has been fitted to the uprights of the radiator mounts.
Wed Jan 17, 2018 7:57 pm
All looking very nice and pristine, unlike mine that seems to get covered in half the dust from the Sahara after a week away :lol:
Thu Jan 18, 2018 6:03 am
Fantastic job keep posting the photos!
Thu Jan 25, 2018 10:44 am
Hello,
Thanks for the support so far!
It is now complete enough to run the engine :D although there have been some teething problems with charging, we have now fixed the problem after many days of head scratching and part changing, we asked the guys on the mk1 forum and the first thing suggested worked. :roll: For those of you wondering it was to do with using an LED warning light. Anyway, it is running well now although it will need a rolling road session in the future. Also, the aforementioned dashboard has been laser cut out of brushed aluminium at a mates work and we fashioned a bending jig to form it. Most things have been fitted to it, just the switches need to be wired. Finally, we temporarily fitted the body and bonnet to see what it looked like. :) Next job is thinking about properly fitting the body and doors.
Ben
Tue May 15, 2018 8:20 pm
