It is currently Sun Apr 19, 2026 8:48 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
Let the Journey Begin
Post Re: Let the Journey Begin
I reckon heat is the right way forward on that. Maybe a few cycles of heat/cool/heat and then plenty of heat and a drift and hammer and it'll come right out.
Good luck and remember the hide gloves!
Tue Jun 09, 2020 9:00 pm
Tried heat & hammer but got nowhere, got it on it's way to cherry red if you turned the workshop light off.
So plan B was drill it out which in the end didn't go too bad, started with a 3mm
Bit of slippage
Pulled it back a little with the 5mm
Then straightened it up with the 8mm
Now the question is do I cut the bolt & weld the end as previous or drill split pin through the pin
Also is there any reason not to put a bracing bar across the lugs to stop the spraining apart?
Thu Jun 11, 2020 5:35 pm
Sorry I may be a bit late but I have the hinges in stock.
They are the same as Rossa 1 & 2.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Fri Jun 12, 2020 8:53 am
LOL, yeah wish you'd replied yesterday as I bought some steel to make new pins & new drills to do the other hinges, but as a matter of interest how much are they? As new may still be an option, although I was considering modifying them to add a grease nipple.
I've tried to find your details before & failed.
Fri Jun 12, 2020 10:43 am
Sorry you couldn't find me.
Rossabitz has been going for 20 years and I thought
most owners knew me. Maybe newer owners don't.
I sell Rossa 1 & 2 and a few K3 spares.
The hinges are £30 each and I have a few left from the
last batch. I probably won't restock as the cost will have
increased and having small batches made is expensive.
As with most of the spares, if you have the facilities you
can make or repair them yourself.
If you want hinges please email me for my bank details.
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Fri Jun 12, 2020 12:21 pm
Thanks Alan I sent an email after your last message, not had a response yet.
Fri Jun 12, 2020 1:24 pm
It's Saturday morning but still no email !
Alan Britton
HUNTINGDON
CAMBS
PE26 2SY
Sat Jun 13, 2020 10:54 am
That's weird,
Sat Jun 13, 2020 12:58 pm
Couple of questions, I thought the K3 used the Rover 114 K series group of cars, I only ask as I'm trying to figure out a wiper problem which I will come to in a minute, but the wiring to the wiper motor is not Rover 114 colours, but Austin Metro colours, I have both manuals & the colours match the Metro.
So the wiper problem in detail, the stalk has 4 positions but 5 functions which appear to be
1. Off
1a. Pull to get a swipe
2. Intermittent
3. Slow
4. Fast
However all I have is in position 2. Slow but with no park, is this normal, I did wonder if the park is now not in the right place this has been disabled?
Sun Jun 14, 2020 6:04 pm
my k3 has all the functions
1. Off
2. Intermittent
3. Slow
4. Fast
And i have park
this was taken form the build manual all you did was change the crank arm
I am trying to make a wiring diagram for my Rossa I have not checked to see if this is correct
Sun Jun 14, 2020 7:29 pm
Once again Thank you, do you know where unit 382 lives, wondering if that has been removed.
Sun Jun 14, 2020 8:11 pm
hi no problem unit 382 is on what I call the back of the fuse box the over side to the fuses
A / WINDSCREEN WIPER RELAY
Mon Jun 15, 2020 11:47 am
Image Image
Mon Jun 15, 2020 12:05 pm
Brilliant, I had that out the other to rehang the drivers door, never noticed a relay, but then again I wasn't looking for one, so it may or may not be there, I also have a MGF harness & box somewhere so that one might be the same if it's missing.
Mon Jun 15, 2020 12:11 pm
So spend most of this afternoon tracing wires & proving things through, got really frustrated as everything should have logically worked, my wiring is definitely different to yours, it follows these colours, where 30 is the motor, 73 the relay, 49 the switch & 44 the washer
Upshot is, pretty sure it's the stalk that is faulty, I cleaned all the terminals & at different times I had everything working, but only by twisting & turning the stalk as I had it on a setting. Before I take it apart I'll see if I can another one the sequence appears to be from the top
1. Fast
2. Slow
3, Off
4. Intermittent
This what I need if somebody has a box of spares
Mon Jun 15, 2020 7:26 pm
