It is currently Sat Aug 15, 2026 6:02 am
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 23  Next
Paul's k3
Post Re: Paul's k3
all nice and flat it juts needs some more holes and a gasket to seal it
Wed Sep 10, 2014 9:38 pm
Post Re: Paul's k3
here is my window washer bottle it has a big hole in the side filed in with some black stuff it does not leak
but it does not look all that great
so I got a new one from e.bay and heated it up with a hot air gun and pushed in the side it fits round the suspension
you can just see it on the side
fits just right and looks much better
Sun Oct 19, 2014 12:03 pm
Post Re: Paul's k3
do you like my new roll bar.
I think I might have to change it
the pipe fittings do not work all that well push fit will work much better :lol:
Wed Nov 26, 2014 12:46 pm
Post Re: Paul's k3
Hot or cold.... :?: :?: :?:
:lol: :lol: :lol:
Wed Nov 26, 2014 6:43 pm
Post Re: Paul's k3
I think this is a bit better
I have to make some bracing to bolt up to the torque tube which is on the other side of the main body tub and runs down to the subframe
Thu Nov 27, 2014 12:06 pm
Post Re: Paul's k3
the roll bar is all done with the bracing and some customer fixing points wich fit the fiberglass in side the tub
i will drill holes through torque tube from the engine compartment side and bolt them together
I have just put some red primer on the roll bar ready for paint
Sat Dec 20, 2014 9:23 pm
Post Re: Paul's k3
I have the rear panel out so i can fit the new roll bar. I have taken the vinyl from the rear panel and filled in the holes from where the seat belts used come out off .
the seat belts are now fixed the th roll bar
and all I have to do is find out how do I get this to fit back in around the roll bar
Sun Jan 25, 2015 2:54 pm
Post Re: Paul's k3
I have been playing with fibreglass for the last few weeks. Have got the rear panel modified
I have got it to fit around the bar it just needs a bit more (a lot more work )
how am I going to get this to fit in the car
Sun Jan 25, 2015 3:17 pm
Post Re: Paul's k3
I have put some black paint on the roll bar its a bit cold for paint
Sun Feb 01, 2015 10:18 pm
Post Re: Paul's k3
Tue Feb 17, 2015 10:31 am
Post Re: Paul's k3
it's in
I got it to fit
Sat Feb 28, 2015 10:03 pm
Post Re: Paul's k3
My car is going for an MOT
if all is Ok I will take it to Stoneleigh kit car show at the weekend
Tue Apr 28, 2015 5:14 pm
Post Re: Paul's k3
The bar is very neat when you see it finished - substantial too! ☺
Tue Apr 28, 2015 6:27 pm
Post Re: Paul's k3
i have just got this to go in my car :D :D :D
Sat May 30, 2015 3:06 pm
Post Re: Paul's k3
Sweet. Looks like you've got everything! That looks like one of the later mems 3 ones too. Hope the swap goes well. I've decided to delay my swap 'till after a track day I've booked for August. I still can't get hold of the PG1 support bracket for the Spyder - might be a different bracket for the K3?
Sat May 30, 2015 10:26 pm
