Ken555
 Re: Kano Coupe
I would have been 4 when they were published.
| Wed Nov 04, 2015 8:59 am |
kano nordie
 Re: Kano Coupe
You young whipper snappers know just where to stick the knife in and old codger  I was just completing my engineering training when you were but a twinkle in your daddies eyes Cheers Ken
| Wed Nov 04, 2015 7:11 pm |
 Re: Kano Coupe
You lot are old! Neil
| Wed Nov 04, 2015 9:53 pm |
Malcolm_Ball
 Re: Kano Coupe
WEST wrote: You lot are old! Neil A few of us will not even bother refuting that. But remember, we have the wisdom of youth with the energy of an elder :p
| Thu Nov 05, 2015 8:23 am |
Steve Shield
 Re: Kano Coupe
Aye -- and some of us used to live int' hole int' road, get up before we went to bed, worked 25 hours a day and had gravel to rub in us hair etc etc -- that's if we'd got any hair.
We're supposed to be older and wiser but we probably remember the Coupe being launched and are still daft enough to be messing around with them!
| Fri Nov 06, 2015 10:58 am |
kano nordie
 Re: Kano Coupe
I remember the Cox being launched and bought the TripleC mag in 1967 (which I still have) thinking one day I will have one, now I'm onto number two, old age is not a cure for madness John
| Fri Nov 06, 2015 7:22 pm |
David Large
 Re: Kano Coupe
I remember the Cox being launched as well and the CCC magazine article - which I no longer have. I had 2 Coupes and still have one of them. They are great cars.
David
| Sat Nov 07, 2015 8:41 am |
kano nordie
 Re: Kano Coupe
Building a GTM is a bit like a dance, one step forward 2 steps back, with an occasional step to one side, 2016 and already its turned to bo**cks. Engine at last into the subframe, now I find my nice LCB exhaust manifold made so long ago and salvaged from my old Cox GTM, fouls where the 2 into 1 collector is bang over the top of the inner pivot and its support bracket for the steering locking system. 2 options; cut and shut the exhaust and all its mounting brackets, or possibly remove the Mini Spares adjustable bottom arms and tie rods and go back to the original Cox A frame lower arms, modified to allow camber adjustment (still in thinking) I will drag out my 2 sets of A frames, have a good check over and decide which way to go. Today is when I have to wear my Tee shirt printed with; Not to get too technical, but according to chemistry alcohol is a solution!! Grrrrrrrrrrrrrr John
| Sun Jan 03, 2016 9:53 am |
kano nordie
 Re: Kano Coupe
Tried to attach picture but the message "sorry, the board attachment quota has been reached" come up, does that mean the early part of this post should be deleted?? John
| Sun Jan 03, 2016 9:57 am |
 Re: Kano Coupe
kano nordie wrote: Tried to attach picture but the message "sorry, the board attachment quota has been reached" come up, does that mean the early part of this post should be deleted?? John Just tweaked a setting try now. Neil
| Sun Jan 03, 2016 11:58 am |
kano nordie
 Re: Kano Coupe
Here we go again
| Sun Jan 03, 2016 12:24 pm |
kano nordie
 Re: Kano Coupe
That's better, shame to cut and shut so the A frames are going into work in the morning and back to the drawing board John
| Sun Jan 03, 2016 12:27 pm |
 Re: Kano Coupe
Cannot say I have seen a LCB go that side of the subframe.
| Sun Jan 03, 2016 12:31 pm |
kano nordie
 Re: Kano Coupe
I was made by a Northants Fabricator whose name I cannot remember and too nice to chop up John
| Sun Jan 03, 2016 12:41 pm |
kano nordie
 Re: Kano Coupe
Hmm just been looking at plan "C" mounting the steering locking arm T'other way around with the steering arms facing the front and the brake calipers mounted to the rear, it is do-able buy needs a slot cut into the sub frame in front of the spring tower to allow the adjustable link to go up and down, there is a plus in that it would need shorter steering arms giving more clearance between the wheel rim. I will finish modifying the old Cox A frame arms for camber adjustment then decide which way to go John
| Sat Jan 09, 2016 5:09 pm |
