It is currently Sun Aug 16, 2026 8:59 am
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 23  Next
Paul's k3
Post Re: Paul's k3
Just been doing a bit of reading on Metro sites as well as on here.
Everything seems to suggest that the hub end of r65 shafts and PG1 shafts should be identical. Mgf rear hubs are supposed to be identical to metro front hubs. Lots of metro owners seem to have had no trouble using PG1 shafts on their metros.
Are K3 rear hubs metro front hubs?
Libra/Spyder rear hubs are simply Metro front hubs so they should fit either drive shaft.
Tue Nov 10, 2015 3:16 pm
Post Re: Paul's k3
Hi I could not get the mgf drive shaft in the metro hub so tried the other metro shaft in the old mgf hub it did not fit
I think it is 1mm bigger I had to go to work so will try to get the metro cv off and see if it fits the mgf one
Tue Nov 10, 2015 6:21 pm
Post Re: Paul's k3
According to rimmer bros the part number for the metro hub drive flange is identical to the part number for the MGF one which supports the theory that the hub ends of the driveshafts should be the same. Very odd that they aren't on yours. you aren't putting the diff end into the hub are you???
Tue Nov 10, 2015 11:08 pm
Post Re: Paul's k3
you are right dave rimmer bros do have the same part number um very odd I have the drive shaft in the diff I did not have much time to have a good look at it. to see how tight are the mgf driveshafts are in the hub I did not wont to jam them in as the metro ones slide in they could just be rusty
big thanks for all your help
Wed Nov 11, 2015 1:06 am
Post Re: Paul's k3
I think he may be able to put the correct end of a drive shaft into the hub........
Just in case, unscrew the nut then insert into drive flange.
The numbers "should" match and the cv's "should" fit...
MGF Front Right Hub - RUB10008 (non ABS)
MGF Front Left Hub - RUB10009 (non ABS)
MGF Trophy Front Right Hub - RFB100120 (ABS) or RFB000020
MGF Trophy Front Left Hub - RFB100130 (ABS) or RFB000030
MGTF Front Right Hub - RUB10008 (non ABS)
MGTF Front Left Hub - RUB10009 (non ABS)
MGTF Front Right Hub - RFB100120 (ABS)
MGTF Front Left Hub - RFB100130 (ABS)
Rover100 Front Right Hub - RUB10008
Rover100 Front Left Hub - RUB10009
The owner isn't
Wed Nov 11, 2015 1:11 am
Post Re: Paul's k3
Comment about shafts being the wrong way round was meant to be a flippant one, not meant seriously - hope not taken the wrong way (no pun!) :)
Wed Nov 11, 2015 8:29 am
Post Re: Paul's k3
My Libras both have Metro rear hubs, modified with eccentric bushes to take MGF calipers. They have PG1 gearboxes VVC engines and MGF driveshafts - no problems fitting. I don't suppose you have A-series drive flanges by any chance - These I don't think will fit. Otherwise there should be no problem, except for rust or damage.
Wed Nov 11, 2015 9:30 am
Post Re: Paul's k3
hi I have just been out and measured the diameter of the diver shafts and there is not much in 0.55
Image Image
I do not know if I have A-series drive flanges
it could be that the mgf ones are just a tight fit which would explain why I could not get them out of the hub.
as you can just see I had to hit it and I might have bent the end of the shaft flat as I had trouble getting them out. I think I will change the cv ends over
The comment about shafts being the wrong way around was funny I did have trouble getting the end in the diff until I unscrewed the nut :lol: :lol: :lol:
Wed Nov 11, 2015 10:43 am
Post Re: Paul's k3
So the mgf one is the one on the left? (bent end and ABS reluctor ring) - if so that one is the smaller one! It does look like there is some corrosion on the splines so thats probably why it was tight. My MGF ones are already removed so that's one problem I shouldn't have! My R65 shaft were moved only about 16 months ago when the previous owner put the 1.6 in so hopefully they won't be seized in, might give them a good squirt of penetrating oil though! Given the damage to that end it looks like you'd have been swapping the CV over anyway!
Wed Nov 11, 2015 2:18 pm
Post Re: Paul's k3
Its all fixed all I did was change over the ends simple
Wed Nov 11, 2015 2:40 pm
Post Re: Paul's k3
Glad I could help. :)
The owner isn't
Wed Nov 11, 2015 4:59 pm
Post Re: Paul's k3
a big thanks to all
I have just tried the short drive shaft in the hub and it fits I must have damaged the long one getting it out of the mgf hub.
:oops: :oops:
thanks to all that helped looking up part numbers reading on Metro sites and things
the size difference must just be down to wear on the metro part so the parts should fit NOPE DO FIT I have just pop them in
had a bit of a setback
I knew it was going too well. I just went to put the drive shafts in a found that MFG drive shafts do not fit the metro hub as I was told. so now I have to change all the suspension to the mgf set up I had to cut the mgf hub to get the driveshaft out as I did not need the this was not a problem but I need the now so have to find 2 mgf hubs :oops: :oops: :twisted: :twisted:
panic over it was a good job I did not change it all to the mgf suspension before asking for help
so where was I two days ago
Thu Nov 12, 2015 9:58 am
Post Re: Paul's k3
Glad you asked and checked, one more thing for men not to worry about when I finally do mine. :)
The owner isn't
Thu Nov 12, 2015 11:55 am
Post Re: Paul's k3
And me! Good result! And we've also learnt to give the driveshaft flanges a good squirt of penetrating oil at the start of the strip!
Thu Nov 12, 2015 8:46 pm
Post Re: Paul's k3
Just a thought about rebuilding stuff so you can get it apart again.
A thin layer of Copper grease on the thread stops stuff seizing and makes disassemble easy, thin smear on the cv splines makes removal easy.
Do not use on things that need Thread locker on them like flywheel bolts.
Great on wheel nuts, and you don't need alot. and for the price its worth keeping the skin on your knuckles , and the bolts in one piece.
The owner isn't
Fri Nov 13, 2015 3:53 pm
