It is currently Fri Nov 27, 2026 9:06 am
Post new topic Reply to topic  [ 379 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 26  Next
Plan “B” ready for trial assembly, using my old 69 Cox A frame lower arms modified to allow camber adjustment and my fabricated upper arms with the knuckle socket move out as per hydro Mini upper arms to effectively stiffen the rear springs, hopefully this will allow me to use the same soft long travel coil springs front and rear. This was all something I thought about trying sometime in the future, but was forced upon me when I found my transverse LCB exhaust was over the top of the inner pivot steering locking system using the more standard camber/caster adjustable Mini upper and lower arms.
For trial fitting I made 2 brass bushes for the upper arm inner pivot, although the tube was machined to accept the normal Mini needle bearings (I do have 2 rebuild kits here) I notice Force used bronze bushes in their fabricated titanium supadupa upper arms and think this is probably a better way to go as I can ream out the 2 bushes in position to fit the shaft.
Sun Jan 17, 2016 9:47 am
Upper arms
Sun Jan 17, 2016 9:48 am
Plan "B" going together, assembled upper and lower arms on left side, still have to modify the bump stop for the right side
Sun Jan 24, 2016 12:13 pm
I had to rotate the caliper back plate as the caliper touched the lower arm, 3 holes drilled job done.
Anybody needing a rear steer locking system mine is available if I bring it back in April :wink:
Sun Jan 24, 2016 12:26 pm
With the reverse A-frame bottom arms, don't forget to drill and tap the uprights and fit the two fixing bolts after setting the rear toe.
Without these bolts the A-frames bend like toffee! - Mine did the first time I accelerated hard :oops:
Wed Jan 27, 2016 9:29 am
I am thinking of something similar, but with rose joints on the outer pick ups and using the 2 bottom bolt holes that the back plate fixes to in the hub as location for the carrier, I don't trust those toe in adjusters at all! I am working on a 3D model at the moment and will post it when I finish.
Wed Jan 27, 2016 2:50 pm
Thanks for the reminder MiniT, they are the original A frames and hubs off my 69 Cox, the 5/16" bolts were remove until the toe in has been set.
Wed Jan 27, 2016 7:06 pm
The GTM builders dance one step forward two back with the occasional sidestep, oil leaking from both ends if my gear selector shaft seals, remember being a crafty old git mine sticks out front and back of the gearbox:wink: They were new when I fitted them and hardly used, just been sitting doing nothing for about 16 years, the front one I was able to dig out, the one in the diff housing pushed further in, so out with the engine to remove the diff cover, am lot of work for 2 poxy shaft seals :cry:
Sun Feb 14, 2016 12:41 pm
This help??
https://www.youtube.com/watch?v=61FMWca5AM8
The owner isn't
Sun Feb 14, 2016 3:26 pm
Hi Bubbles a good video, But --- mine was built up in Kano and not quite standard, I used industrial shaft seals onto a 15mm diameter longer selector shaft which passes through and out of the front of the box, the seals were out in time for lunch, I'll find replacements in the week, ready for the next installment :roll:
Sun Feb 14, 2016 4:57 pm
Plane C+D, my spare and worst subframe modified to allow the possibility of the steering locking system to be mounted ln front of the upper arm pivots
Sat Mar 12, 2016 4:27 pm
Plenty of rat holes to lose nearly 3Kg from the standard subframe :mrgreen:
Sat Mar 12, 2016 4:29 pm
Nice work John, every little helps!
Sat Mar 12, 2016 8:20 pm
Are any of you using 14”x6” rims on a road going coupe and if so what aspect ratio tyres are needed not to have clearance problems? I used to run 13”x6” rims using 13 x175-50 Pirelli P7 back in the day on my old Cox without clearance problems but had to fit flared arches to keep the “scrutes” happy when racing.
The reason of asking is that I can buy quite nice alli 13” wheels here for Toyota Corolla, but only with 100mm pcd stud fixing and my Corolla hub flanges have a 114.3mm pcd, which I buy a 14” size wheel to fit.
Answers accepted on the back of a £20 note please
Tue Mar 15, 2016 6:27 pm
Engine and suspension assembled into modified subframe
Sat Mar 26, 2016 9:07 am
Users browsing this forum: Google [Bot] and 3 guests
