It is currently Fri Jun 05, 2026 4:05 pm
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 23  Next
Paul's k3
Post Re: Paul's k3
we have a MOT
it's back on the road. there is still some more work to do but there are all way bits to do on a kit car
I have not been out in it yet to see how well it runs but when I went for the MOT the gear change was a lot better
it was raining so could not test the 1.8 vvc
Sat Jul 02, 2016 9:50 am
Post Re: Paul's k3
Great news, just have to wait for some dry weather.......
The owner isn't
Sat Jul 02, 2016 9:34 pm
Post Re: Paul's k3
Great you are back on the road. There is a rumour that summer will be coming soon so should be some opportunities to try it out!
Sat Jul 02, 2016 10:12 pm
Post Re: Paul's k3
Good news Paul, well done mate!
Mon Jul 04, 2016 12:41 pm
Post Re: Paul's k3
I would like to Thank you all for your help
I hope to get out in it someday soon
Mon Jul 04, 2016 5:04 pm
Post Re: Paul's k3
back on page 10 I found the latch hits the head
I have just found that the boot latch hits the cylinder head which looks ok in the photo but the engine is not pushed back yet
I was thinking I can I just move the boot latch to the side?
I was going to dump it and make a new catch from a bearclaw latch from CBS.
but I fixed the problem by mounting the boot latch on top of the bracket this lifted the latch so it now misses the cylinder head.
this works fine all I had to do was wind the spring in a bit to bring the boot down
the cable for the boot latch runs inside the cover and out the end, I might have to get a new cable.
when I started the engine the cable was sitting on the exhaust manifold :roll: and melted the outside plastic
it does work ok still but might rust one day
Tue Jul 05, 2016 10:18 am
Post Re: Paul's k3
I have not done much to the car but have had a go at the hardtop that came with my car this
did not fit so had to cut and make it fit. its is all so yellow so will need a paint
Wed Aug 03, 2016 10:09 am
Post Re: Paul's k3
Hi,
I know this was posted quite a while ago but what is the dash out of.
The K3 I have seen is a metro dash and they are ugly
Mon Sep 12, 2016 3:41 pm
Post Re: Paul's k3
the dash in my k3 is custom made the cluster of clocks Is from an mgf
and also the Dashboard Binnacle is from mgf like this one from eBay
http://www.ebay.co.uk/itm/MGF-MG-TF-Das ... 2068658419
the heater controls are from car builder solution
http://www.carbuildersolutions.com/uk/s ... controller
http://www.carbuildersolutions.com/uk/p ... fan-switch
and the glove box is custom made
hope this helps
Mon Sep 12, 2016 4:56 pm
Post Re: Paul's k3
I have started work on the hardtop which came with my car
Sat Sep 24, 2016 8:40 pm
Post Re: Paul's k3
I have fitted an mgf heater control vale to my car to stop the heater being on all the time
Thu Oct 20, 2016 8:51 pm
Post Re: Paul's k3
the sun has finally come out so I went out in the car but I think it has mice it squeaks a lot
see video
https://drive.google.com/file/d/0B80Cte ... sp=sharing
can anyone help what would be the best thing to use
on the rubber bushes to stop it squeaking
regards
paul
Sun Apr 09, 2017 5:06 pm
Post Re: Paul's k3
It may not be the bushes. My K3 squeaked like hell before I took it to pieces and it turned out to be the back of the front subframe rubbing on the body tub. Just check for clearance first.
Peter.
Sun Apr 09, 2017 8:37 pm
Post Re: Paul's k3
hi
I went to fill the car up with petrol but could not get the pump nozzle in the car very well
when I got home I found that the Ultra Flexible Fuel Filler Hose that I got from car builder solutions
has a rubber-like inner inside it looks like it has come away from the outer so I can not get the pump nozzle in
I have not had it on the car for long
does anyone know how Flexible the BLACK SILICONE Fuel Filler Hose is that they sell
or any type of hose which will do the job
paul.
Fri Apr 14, 2017 6:04 pm
Post Re: Paul's k3
If you haven't had it long I would be contacting the sellers....not fit for purpose sales of goods act, refund.......??
Fuel filler pipes usually last longer than the cars they are fitted to.
I would look for a genuine, car part,(Ford,Vaxhall,Rover Etc) that will do the job, I know you have an alloy tank and modded fuel system, so you will know what is likely to fit/angle/bends required etc.
The owner isn't
Sat Apr 15, 2017 10:36 am
