It is currently Tue May 26, 2026 6:14 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
Cumbrian coupe
Post Re: Cumbrian coupe
lakelandgtm wrote:
turbocox wrote:
That loom looks a lot better than mine :shock:
Did you make your own loom? :D
No I didn't make it, but every time I touch it it still seems to have more smoke built up inside the plastic sleeving
It just keeps coming out everywhere, :shock:
How does it get in :?:
Mon Sep 12, 2016 9:44 am
Malcolm_Ball wrote:
Can't You take it in to work and get someone to look at it ? :P
It's not like the old days, your given so much work and so little time to do it in that you can't leave your work area, and nobody in any of the other departments want to help out as they don't have time either :cry:
Mon Sep 12, 2016 9:46 am
You used to be able to buy jars of smoke to refill your wiring loom. Not sure if they're still available..........! :lol: :lol: :lol: :lol:
Mon Sep 12, 2016 11:44 am
Are the tail brackets on the rear subframe needed for anything? Because the previous owner has cut them off.
Thu Oct 27, 2016 7:59 am
Only if you want to use them to mount a silencer, that is what I used them for on my old old old setup
Thu Oct 27, 2016 10:37 am
As West says some people use them to mount the exhaust although I prefer to attach it to the back of the engine so it all moves together. Also some rear facing RH gearbox steady bars mount to the bolt holes so avoid them -- other steady bars are available.
Fri Oct 28, 2016 8:49 am
Preparation on the tub is going well, alongside building the engine and subframes. The subframes and compomotive cx wheels have been powder coated in black, which you can see below, in my opinion they look pretty cool. :lol: We are currently working on fitting the pedal box, which should be completed soon. :D
Wed Feb 01, 2017 9:14 pm
Too much black :)
Thu Feb 02, 2017 12:08 am
Ben welcome to the forum nice little project you have there you may find your insurance is cheaper than a conventional car also good luck with the project
Ian
Thu Feb 02, 2017 9:02 am
Looking good, it'll be rolling before you know it.
Fri Feb 03, 2017 10:32 am
After a struggle the engine is in the subframe, and now onto the car. Pictures will be posted soon. But while we were fitting it we noticed that the clutch slave cylinder return spring hits the chassis, so we had to remove it. Is this normal? And is there a different way to attach the spring?
Wed Feb 22, 2017 6:59 pm
I remember having a similar issue on mine when I was A series powered. I ended up profiling the arm around the pin to increase clearance. I did get a return spring fitted too.
Also think some careful positioning of the engine on the steady bars helped and having the engine fairly stiff made sure it never caught.
Wed Feb 22, 2017 7:46 pm
The early Cox build recommended the clutch arm should be bent a little to give a clearance with the more bulky early sheet metal chassis, cant remember how much but it was shown in the CCC GTM build project.
Thu Feb 23, 2017 7:19 am
Lovely looking coupe you have got there and your making a good job of the restoration, keep up the good work and don't let small problems dampen your enthusiasm :D :D
Jamie
Libra V6
Hawk AC Ace
TVR 3000M
MG ZTT 180
Skoda Fabia VRS
Fri Feb 24, 2017 10:20 pm
Rear subframe along with engine and hubs are now fitted onto the chassis. Steering locking kit and handbrake kit also fitted, courtesy of Alan at Rossabitz.
Front subframe hasn't been put in yet so the old wheels are counterbalancing the weight of the engine. :D
Mon Feb 27, 2017 10:36 pm
