It is currently Fri Nov 27, 2026 1:06 pm
Post new topic Reply to topic  [ 379 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 26  Next
Fitting Toyota brakes refurbed with seals supplied by BiggRed
Sun Oct 18, 2015 10:45 am
Adjustable bottom arms and tie rods made in Kano - Mini Spares (metric) copies :wink:
Sun Oct 18, 2015 10:48 am
the blunt end all spherical joints, bottom arms and tie rods Mini Spares
Sun Oct 18, 2015 10:49 am
more blunt end
Sun Oct 18, 2015 10:50 am
And finally
Sun Oct 18, 2015 10:51 am
I removed the bias bar brake peddles from the Twinny Mini
Sun Oct 25, 2015 2:57 pm
These are a pair of Girling cylinders fed by a common reservoir assembled into a modified Mini peddle box
Sun Oct 25, 2015 2:59 pm
I will strip and clean, must be at least 20 years since I made it :oops: then cut the peddle to shorten them for GTM duty :wink:
Sun Oct 25, 2015 3:01 pm
The Mini bias bar dual cylinder peddles cut as per the Triple C GTM build project of so long ago, just as well I kept all those old magazines relating to GTM.all cleaned up and painted
Tue Nov 03, 2015 7:44 pm
Modified Mini peddle box
Tue Nov 03, 2015 7:50 pm
another pic
Tue Nov 03, 2015 7:51 pm
Dual bias Mini peddle box assembled
Tue Nov 03, 2015 8:01 pm
Not too hard to make and just the cost of 2 cylinders and a bias bar
Tue Nov 03, 2015 8:02 pm
"Building your own mini-based G.T. Car" starting Nov 1969
I have electronic copies of them.
Along with the June 1967 road test
Wed Nov 04, 2015 12:32 am
:wink: I have paper hard copies saved since they were published :D
Wed Nov 04, 2015 4:16 am
