kano nordie
 Re: Kano Coupe
Fitting Toyota brakes refurbed with seals supplied by BiggRed
| Sun Oct 18, 2015 10:45 am |
kano nordie
 Re: Kano Coupe
Adjustable bottom arms and tie rods made in Kano - Mini Spares (metric) copies
| Sun Oct 18, 2015 10:48 am |
kano nordie
 Re: Kano Coupe
the blunt end all spherical joints, bottom arms and tie rods Mini Spares
| Sun Oct 18, 2015 10:49 am |
kano nordie
 Re: Kano Coupe
more blunt end
| Sun Oct 18, 2015 10:50 am |
kano nordie
 Re: Kano Coupe
And finally
| Sun Oct 18, 2015 10:51 am |
kano nordie
 Re: Kano Coupe
I removed the bias bar brake peddles from the Twinny Mini
| Sun Oct 25, 2015 2:57 pm |
kano nordie
 Re: Kano Coupe
These are a pair of Girling cylinders fed by a common reservoir assembled into a modified Mini peddle box
| Sun Oct 25, 2015 2:59 pm |
kano nordie
 Re: Kano Coupe
I will strip and clean, must be at least 20 years since I made it  then cut the peddle to shorten them for GTM duty
| Sun Oct 25, 2015 3:01 pm |
kano nordie
 Re: Kano Coupe
The Mini bias bar dual cylinder peddles cut as per the Triple C GTM build project of so long ago, just as well I kept all those old magazines relating to GTM.all cleaned up and painted
| Tue Nov 03, 2015 7:44 pm |
kano nordie
 Re: Kano Coupe
Modified Mini peddle box
| Tue Nov 03, 2015 7:50 pm |
kano nordie
 Re: Kano Coupe
another pic
| Tue Nov 03, 2015 7:51 pm |
kano nordie
 Re: Kano Coupe
Dual bias Mini peddle box assembled
| Tue Nov 03, 2015 8:01 pm |
kano nordie
 Re: Kano Coupe
Not too hard to make and just the cost of 2 cylinders and a bias bar
| Tue Nov 03, 2015 8:02 pm |
Ken555
 Re: Kano Coupe
"Building your own mini-based G.T. Car" starting Nov 1969 I have electronic copies of them.
Along with the June 1967 road test
| Wed Nov 04, 2015 12:32 am |
kano nordie
 Re: Kano Coupe
 I have paper hard copies saved since they were published John
| Wed Nov 04, 2015 4:16 am |
