kano nordie
 Re: Kano Coupe
Hi Sanzo, That looks about right, PM your fone number and we can meet up in a Motorway stop, I'll be in the truck park with a blue Land Rover 110 and alli box race car trailer Cheers john
| Fri Apr 15, 2016 8:44 am |
 Re: Kano Coupe
kano nordie wrote: Hi Sanzo, That looks about right, PM your fone number and we can meet up in a Motorway stop, I'll be in the truck park with a blue Land Rover 110 and alli box race car trailer Cheers john Hi John, Slight change of plan - I've broken my Spyder at a track day yesterday at Castle Combe! No baffles in the sump and I think I've lost a big end shell most likely due to oil starvation whilst cornering. Won't be fixed in time for Stoneleigh and doesn't seem right to come up without a kit car, plus I'll need the time to investigate the repair. I've put out a message on KitNet.uk (a new forum site intended to link clubs together but currently mainly SW based) to see if any of the guys local to me who are going to Stoneleigh can take the cable up with them...
| Tue Apr 26, 2016 5:36 pm |
grizzler73
 Re: Kano Coupe
Hi John Can you tell me where you got your exhaust manifold/system? It looks nice! Simon
| Mon May 02, 2016 11:24 am |
kano nordie
 Re: Kano Coupe
sanzomat wrote: kano nordie wrote: Hi Sanzo, That looks about right, PM your fone number and we can meet up in a Motorway stop, I'll be in the truck park with a blue Land Rover 110 and alli box race car trailer Cheers john Hi John, Slight change of plan - I've broken my Spyder at a track day yesterday at Castle Combe! No baffles in the sump and I think I've lost a big end shell most likely due to oil starvation whilst cornering. Won't be fixed in time for Stoneleigh and doesn't seem right to come up without a kit car, plus I'll need the time to investigate the repair. I've put out a message on KitNet.uk (a new forum site intended to link clubs together but currently mainly SW based) to see if any of the guys local to me who are going to Stoneleigh can take the cable up with them... Dry sump it after the rebuild  I got back to Kano at 5.30 this morning, 30c when they opened the door, I'll see if i can find out where I gat the system fabricated and if they still exist? I turned up at Stoneleight with a L-R 110 with GTMOC stickers on the screen Cheers John
| Fri May 06, 2016 10:20 am |
kano nordie
 Re: Kano Coupe
Hi Grizzla, Having wracked my brain I think my exhaust was made by Intek Engineering and Fabrications T 01604 765555 in the mid 1980's it was a one off and my car was with them for a few day when they fabricted it, they were working on mostly classic sports and race cars. I would be most surprised if they still have records or drawings of it after all this time, If you are really interested I could measure it up and make a drawing?
| Tue May 10, 2016 7:39 am |
Steve Shield
 Re: Kano Coupe
Having had another look at that manifold I wonder whether its adapted from a Spridget part.
| Tue May 10, 2016 8:50 am |
kano nordie
 Re: Kano Coupe
Worth looking at a spridget LCB, the silencer used on mine was the middle box from a V12 E type Jag John
| Tue May 10, 2016 9:44 am |
grizzler73
 Re: Kano Coupe
Thanks for the brain wracking john, I was looking at a A35/A40 one as the mini version is too far back by the time you get to the end of the "Y" http://www.maniflow.co.uk/index.php?vie ... oduct=1146It is nice and compact. I hadn't got as far as the silencer so that is good to know!
| Tue May 10, 2016 1:09 pm |
Ken555
 Re: Kano Coupe
As long as you're not using the mechanical fuel pump then you are ok.
The mini based units are designed to clear the pump.
| Tue May 10, 2016 1:46 pm |
kano nordie
 Re: Kano Coupe
Ken555 wrote: As long as you're not using the mechanical fuel pump then you are ok.
The mini based units are designed to clear the pump. Mechanical fuel pump! whats that?? extra power loss, go electric  my pump will be under the bonnet next to the tank John
| Tue May 10, 2016 1:52 pm |
kano nordie
 Re: Kano Coupe
grizzler73 wrote: Thanks for the brain wracking john, I was looking at a A35/A40 one as the mini version is too far back by the time you get to the end of the "Y" http://www.maniflow.co.uk/index.php?vie ... oduct=1146It is nice and compact. I hadn't got as far as the silencer so that is good to know! When ist built up with a big engine I had used a Mini LCB cut and rewelded I probably have pictures if needed John
| Tue May 10, 2016 1:57 pm |
Steve Shield
 Re: Kano Coupe
I used a mini LCB cut and shut so that the Y piece is at 90deg to the centre line of the car with the pipe running under the right hand subframe leg. As well as being a bit of a 3 dimensional jig saw this does have 2 technical issues:
1. the pipe under the subframe leg does limit ground clearance 2. one of the pipes -- the centre pipe I think -- needs to be extended by about 2 inches using a sleeve I bought from the local parts shop which I think screws up the pulse tuning -- not that I've noticed!
One other thing worth doing is to mount the silencer on to the powertrain unit rather than the subframe so that it all rocks with the engine -- avoids stressing the system leading to a physical failure.
| Tue May 10, 2016 5:29 pm |
grizzler73
 Re: Kano Coupe
I was thinking that going under the subframe would be a bad idea, give that I will be lowering in as much as allowed. The in-line LCB is definitely looking the favourite
| Tue May 10, 2016 7:52 pm |
kano nordie
 Re: Kano Coupe
And attach to the engine/gearbox as Steve suggested John
| Wed May 11, 2016 4:19 am |
kano nordie
 Re: Kano Coupe
Just bought 4 BBS 13" wheels for Toyota hole pattern at less than 50 quid I still have the 13"x6 wheel bought off Runk the Punk in the UK if anybody is interested John
| Sun Jun 05, 2016 2:34 pm |
