kano nordie
 Re: Kano Coupe
Dash as simple as it can get!!
| Wed Jul 05, 2017 6:40 am |
kano nordie
 Re: Kano Coupe
Front end from L side
| Wed Jul 05, 2017 6:41 am |
kano nordie
 Re: Kano Coupe
just to show I'm not biased now from the R side
| Wed Jul 05, 2017 6:42 am |
kano nordie
 Re: Kano Coupe
Dash, battery isolator, ignition and and starter button
| Wed Jul 05, 2017 6:44 am |
kano nordie
 Re: Kano Coupe
My cheap local purchase 50quid wheels fitted with 165-70 just to check clearances in case I cant find 60 series tyres
| Wed Jul 05, 2017 6:46 am |
kano nordie
 Re: Kano Coupe
One step forward at least 2 steps back, assembled my steering column with 2 U/J's to give a better alignment on my L-H drive installation, the good news is it does,"BUT" I now have a slight foul on the brake peddle, OK strip out the brake/clutch assembly, remove the brake peddle and put a little kink into the lever each side of the cut and shut joint, then found 1 of the brake cylinders on the bias bar assembly is seized, (it has been outside more than a year) so take the whole assembly into work where I have compressed air to blow the pistons out and to clean John
| Mon Jul 10, 2017 7:02 am |
Ken555
 Re: Kano Coupe
Need pics of column as that's on to do list.
| Mon Jul 10, 2017 11:17 am |
kano nordie
 Re: Kano Coupe
Hi Ken, The peddle box is at work being tweeked, if it all goes together OK next week I'll take some pictures, the biggest problem in L-H drive is there is not enough room to pass the column between brake and clutch peddles as would be normal in a Mini or R-H drive GTM, to give enough room for the brake and accelerator peddle next to the center tunnel the brake peddle must be to the left hand side of the column, big feet would end up at the chiropodist John
| Mon Jul 10, 2017 12:13 pm |
Ken555
 Re: Kano Coupe
kano nordie wrote: Hi Ken, if it all goes together OK next week I'll take some pictures, No rush, I'm currently sitting almost on the equator, not home for a few weeks as I work my way northwards.
| Mon Jul 10, 2017 5:22 pm |
kano nordie
 Re: Kano Coupe
Hi Ken, I'm not far above the equator, call in as you come north  Star beer in the fridge. John
| Tue Jul 11, 2017 5:57 am |
kano nordie
 Re: Kano Coupe
column with 2 u/j's
| Mon Jul 17, 2017 7:25 am |
kano nordie
 Re: Kano Coupe
column missing peddles
| Mon Jul 17, 2017 7:26 am |
kano nordie
 Re: Kano Coupe
"small' steering wheel??
| Mon Jul 17, 2017 7:27 am |
kano nordie
 Re: Kano Coupe
nether regions
kano nordie
 Re: Kano Coupe
nether regions 2
| Mon Jul 17, 2017 7:28 am |
