Re: Paul's k3
That air filter kit looks good - do you have a link to where you got it?
Sun Jan 14, 2018 9:34 pm |
catsam
Joined: Thu Jun 27, 2013 11:32 pm Posts: 492 Location: Norfolk GTM: Libra
Re: Paul's k3
I got it from eBay there are loads of them on their just Search carbon fiber air filter it was only £18 the kit was a lot better than I expected
Mon Jan 15, 2018 6:46 pm |
bubbleless
Re: Paul's k3
I know this is a silly question ... here goes ....does the enclosed filter make it quieter...??
The owner isn't
Tue Jan 16, 2018 12:51 am |
catsam
Re: Paul's k3
Hi have not taken the car out for a drive so do not know If it's any quieter I can't think why it would be
Tue Jan 16, 2018 2:38 pm |
catsam
Re: Paul's k3
I have this hole in the side of my car I was going to use this hole and ducked it to the side vent on the outside but I was thinking the side vents might be a bit low on the side of the car. and this might suck in water
Sun Jan 21, 2018 12:46 pm |
catsam
Re: Paul's k3
Wed Jan 24, 2018 9:30 pm |
catsam
Re: Paul's k3
Sun Feb 25, 2018 11:10 pm |
catsam
Re: Paul's k3
following from the post brake-upgrade-for-k3-t3742.htmlI got a set of rover metro brake pedals from eBay you can see how much of the pedal was cut off
Sun Apr 15, 2018 12:13 am |
catsam
Re: Paul's k3
Sun Apr 15, 2018 12:29 am |
catsam
Re: Paul's k3
you can see on the plate which holds the clutch and brake master cylinder the clutch is now not in line with the brake as I have moved the pivot point back I filled in the hole with some steal and move the hole dawn to line up with the brake pivot point
Sun Apr 15, 2018 12:38 am |
catsam
Re: Paul's k3
I stripped off paint and had it powder coated nice and shiny
Sun Apr 15, 2018 12:52 am |
Re: Paul's k3
Nice work. The difference in pedal ratio is massive! no wonder we have to stand on them! (assume its a similar ratio for the Spyder)
Sun Apr 15, 2018 8:19 pm |
catsam
Re: Paul's k3
I have been out in the car thanks Peter for the drawing the Brakes feel way better than before
Sat Apr 21, 2018 4:59 pm |
jaybee
Re: Paul's k3
Paul.
When you installed the VVC engine and box, did you use the MGF gear cables and shifter, and if so, did you need to modify anything and/or cut off the shifter balance weight?
J.
Fri May 18, 2018 2:16 pm |
catsam
Re: Paul's k3
hi I did you use the MGF gear cables and shifter, all I did to my one was put some threaded rod in the 4 holes in the corners I did cut off the shifter balance weight? works ok in my car you just need to check there are two different cable setups on the gearbox end the Gearbox Gear Selector Linkage Brackets I think
Fri May 18, 2018 3:10 pm |
