Joined: Sun Oct 19, 2014 10:10 pm Posts: 1170 Location: Bristol GTM: Spyder
 Re: Paul's k3
That air filter kit looks good - do you have a link to where you got it?
| Sun Jan 14, 2018 9:34 pm |
catsam
 Re: Paul's k3
I got it from eBay there are loads of them on their just Search carbon fiber air filter it was only £18 the kit was a lot better than I expected
| Mon Jan 15, 2018 6:46 pm |
bubbleless
 Re: Paul's k3
I know this is a silly question ... here goes ....does the enclosed filter make it quieter...??
The owner isn't
| Tue Jan 16, 2018 12:51 am |
catsam
 Re: Paul's k3
Hi have not taken the car out for a drive so do not know If it's any quieter I can't think why it would be
| Tue Jan 16, 2018 2:38 pm |
catsam
 Re: Paul's k3
I have this hole in the side of my car  I was going to use this hole and ducked it to the side vent on the outside but I was thinking the side vents might be a bit low on the side of the car. and this might suck in water
| Sun Jan 21, 2018 12:46 pm |
catsam
 Re: Paul's k3
| Wed Jan 24, 2018 9:30 pm |
catsam
 Re: Paul's k3
| Sun Feb 25, 2018 11:10 pm |
catsam
 Re: Paul's k3
following from the post brake-upgrade-for-k3-t3742.htmlI got a set of rover metro brake pedals from eBay you can see how much of the pedal was cut off
| Sun Apr 15, 2018 12:13 am |
catsam
 Re: Paul's k3
| Sun Apr 15, 2018 12:29 am |
catsam
 Re: Paul's k3
you can see on the plate which holds the clutch and brake master cylinder the clutch is now not in line with the brake as I have moved the pivot point back I filled in the hole with some steal and move the hole dawn to line up with the brake pivot point
| Sun Apr 15, 2018 12:38 am |
catsam
 Re: Paul's k3
I stripped off paint and had it powder coated nice and shiny
| Sun Apr 15, 2018 12:52 am |
 Re: Paul's k3
Nice work. The difference in pedal ratio is massive! no wonder we have to stand on them! (assume its a similar ratio for the Spyder)
| Sun Apr 15, 2018 8:19 pm |
catsam
 Re: Paul's k3
I have been out in the car thanks Peter for the drawing the Brakes feel way better than before
| Sat Apr 21, 2018 4:59 pm |
jaybee
 Re: Paul's k3
Paul.
When you installed the VVC engine and box, did you use the MGF gear cables and shifter, and if so, did you need to modify anything and/or cut off the shifter balance weight?
J.
| Fri May 18, 2018 2:16 pm |
catsam
 Re: Paul's k3
hi I did you use the MGF gear cables and shifter, all I did to my one was put some threaded rod in the 4 holes in the corners  I did cut off the shifter balance weight?  works ok in my car you just need to check there are two different cable setups on the gearbox end the Gearbox Gear Selector Linkage Brackets I think
| Fri May 18, 2018 3:10 pm |
