It is currently Fri Apr 19, 2024 4:28 am
Post new topic Reply to topic  [ 335 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 23  Next
Paul's k3
Post Re: Paul's k3
That air filter kit looks good - do you have a link to where you got it?
Sun Jan 14, 2018 9:34 pm
Post Re: Paul's k3
I got it from eBay there are loads of them on their just
Search carbon fiber air filter it was only £18 the kit was a lot better than I expected
Mon Jan 15, 2018 6:46 pm
Post Re: Paul's k3
I know this is a silly question ... here goes ....does the enclosed filter make it quieter...??
The owner isn't
Tue Jan 16, 2018 12:51 am
Post Re: Paul's k3
Hi have not taken the car out for a drive so do not know
If it's any quieter I can't think why it would be
Tue Jan 16, 2018 2:38 pm
Post Re: Paul's k3
I have this hole in the side of my car
I was going to use this hole and ducked it to the side vent on the outside but I was thinking the side vents might be a bit low on the side of the car. and this might suck in water
Sun Jan 21, 2018 12:46 pm
Post Re: Paul's k3
i made a bracket to hold the air box it just needs some black paint
Image Image Image Image
Wed Jan 24, 2018 9:30 pm
Post Re: Paul's k3
Sun Feb 25, 2018 11:10 pm
Post Re: Paul's k3
following from the post brake-upgrade-for-k3-t3742.html
I got a set of rover metro brake pedals from eBay
you can see how much of the pedal was cut off
Sun Apr 15, 2018 12:13 am
Post Re: Paul's k3
I made a jig so when I removed the shaft I could see where to line the new hole for the pivot shaft
I filed the hole in with some steal and re-drilled the hole in the new position
Image Image
Image Image
Sun Apr 15, 2018 12:29 am
Post Re: Paul's k3
you can see on the plate which holds the clutch and brake master cylinder
the clutch is now not in line with the brake
as I have moved the pivot point back
I filled in the hole with some steal and move the hole dawn to line up with the brake pivot point
Image Image
Sun Apr 15, 2018 12:38 am
Post Re: Paul's k3
I stripped off paint and had it powder coated nice and shiny
Image Image
Sun Apr 15, 2018 12:52 am
Post Re: Paul's k3
Nice work. The difference in pedal ratio is massive! no wonder we have to stand on them! (assume its a similar ratio for the Spyder)
Sun Apr 15, 2018 8:19 pm
Post Re: Paul's k3
I have been out in the car thanks Peter for the drawing the Brakes feel way better than before
Sat Apr 21, 2018 4:59 pm
Post Re: Paul's k3
Paul.
When you installed the VVC engine and box, did you use the MGF gear cables and shifter, and if so, did you need to modify anything and/or cut off the shifter balance weight?
J.
Fri May 18, 2018 2:16 pm
Post Re: Paul's k3
hi I did you use the MGF gear cables and shifter, all I did to my one was put some threaded rod in the 4 holes in the corners
I did cut off the shifter balance weight?
works ok in my car you just need to check there are two different cable setups on the gearbox end the Gearbox Gear Selector Linkage Brackets I think
Fri May 18, 2018 3:10 pm
