Elansprint
 Re: Paul's k3
They have not got a clue and have never had to work in a commercial company where you have to look after customers to pay the wages. I would not call in those Welsh prisons are not too good LOL Ian
| Wed Apr 20, 2016 12:54 pm |
oliverracing
Joined: Sat Nov 07, 2015 6:44 pm Posts: 67 Location: Oxfordshire / Loughborough GTM: K3
 Re: Paul's k3
| Wed Apr 20, 2016 1:43 pm |
catsam
 Re: Paul's k3
nice to hear that so are you going to be able to make it to Stoneleigh
| Wed Apr 20, 2016 2:28 pm |
oliverracing
 Re: Paul's k3
Quote: nice to hear that so are you going to be able to make it to Stoneleigh Hopefully, I'll definitely be there, and whether the car comes or not depends on how the test drive the day before goes...
| Thu Apr 21, 2016 9:08 am |
catsam
 Re: Paul's k3
my car will not be going to Stoneleigh this year but I will  . hope your test drive goes OK oliverracing I have started on the panel for the fuel tank the old one did not fit I don't think I will make one out of aluminum sheet as Peter did in the newsletter I'm going to have a go at making it out of fiberglass this will be fun what can go wrong
| Tue Apr 26, 2016 12:26 pm |
PEEPS
 Re: Paul's k3
Damned annoyed at not being able to get the K3 to Stoneleigh. I need a couple more weeks cos work gets in the way! Managed to get the suspension up and set, I have gone for 200lbs front springs and 300lbs rear as a starting point with adjustable dampers to add stiffness when needed. Corner weighting took all day but satisfied with results, 4 kgs front and 11kgs rear with my weight included. Just the really annoying bits to finish off before MOT.
| Tue Apr 26, 2016 1:42 pm |
catsam
 Re: Paul's k3
after having a grate day at stoneleigh  I did a bit more to of my fuel tank cover I made a cover with card and paper and lots of pva glue.  the plan was to cover the inside with something to stop the fiberglass sticking to the paper but I forgot to do it that will be fun to get the paper off  I have started to make a PVC cover
| Mon May 02, 2016 2:54 pm |
catsam
 Re: Paul's k3
I have done the cover it looks different in the car it should be gray
| Thu May 19, 2016 9:03 pm |
catsam
 Re: Paul's k3
| Sun May 29, 2016 8:05 pm |
Joined: Sun Oct 19, 2014 10:10 pm Posts: 1170 Location: Bristol GTM: Spyder
 Re: Paul's k3
Great! hopefully in time to enjoy the better weather that is going to come now! Let us know how much better it feels now.
| Sun May 29, 2016 11:01 pm |
catsam
 Re: Paul's k3
I still do not have my car on the road I went to see if my locale MOT to see if they would cheek my car as I need to provide evidence for the DVLA ( written confirmation of the change on headed paper from an independent garage ) but they did not no what to do but they did say I could try http://www.tigerracing.com/I did not know they was just up the road from me I phoned them and they can do what I need for DVLA to change the logbook got it done the Radiator was not getting hot. the hot water was getting to the radiator it has a new water pump and I have tested the thermostat:?  so I had a look at the old engine to see if it had a lower opening temp and found this inside   its go the outer part of the thermostat in it so, for now, I have put it in my new engine as it was working fine on the old one I do not use the car in the winter so don't think it will need it to shut it will be like its open all the time I will have to see how this works out
| Wed Jun 08, 2016 11:03 am |
bubbleless
 Re: Paul's k3
Wonder why they wanted so much flow of water, were there any problems with the engine??
You may find it never gets to temperature or only very slowly, not good for power or the engine really.
I have seen a less severe mod where they drill another hole in the outer edge of a normal thermostat to increase the bypass effect so warming the radiator loop up slowly insted of a big hot rush and the engine getting a cold shock from the incoming cool water from the radiator.
The owner isn't
| Wed Jun 08, 2016 11:59 am |
 Re: Paul's k3
Looks like that one already had the hole drilled version prior to taking the whole innards out.
It may be that it had been plumbed with a remote stat or PRT. When you add one of those it is normal to cut the innards out of the normal stat 'cos you need the metal ring inside the rubber to make it seal right but clearly you don't want two stats in the system.
| Wed Jun 08, 2016 10:20 pm |
SparkyB
Joined: Fri Aug 07, 2015 1:39 pm Posts: 20 Location: Chippenham Wilts. GTM: K3
 Re: Paul's k3
Hi, Is this is the only thermostat in the system? Are you running a manual or electric water pump?
Engines are designed to run at a single temperature. If you load the engine while cold it is likely to wear more quickly and more noticeably the fuel injection could think you should be on a choke setting. The throttle response of my V6 Mazda is definitely different before it warms up.
I have read various things about the K-Series and some suggest that the lag in opening and shutting of the thermostat can cause thermal shock to the head gasket. Perhaps they look it out to help save the head gasket?
I guess this way you will not suffer head gasket failure through shock....
| Thu Jun 16, 2016 1:39 pm |
catsam
 Re: Paul's k3
hi sanzomat now you say this Quote: It may be that it had been plumbed with a remote stat or PRT. it did have a PRT fitted but when I got the car it was taken of he did say that it did not work ]  I have only the one thermostat in the system I am running a manual water pump at some point I will be changing the radiator to this one  so until I get it back on the road it will stay as it is one more thing to put on the list
| Fri Jun 17, 2016 8:01 pm |
