It is currently Sat Nov 28, 2026 10:06 am
Post new topic Reply to topic  [ 379 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 26  Next
I have to use the flexible rack and wheel box, my tank would get in the way to use push rods
Thu Aug 25, 2016 3:42 am
Ill write something up on the wiper.
Thu Aug 25, 2016 9:54 pm
http://www.carbuildersolutions.com/uk/tapered-splined-shaft-windscreen-wiper-wheelbox
This is the one I looked at when I was thinking of swapping, but found some normal straight ones on a Landrover in the scrap yard for free.
The tapered ones are fitted the later TD5 defenders but I never found one.
Fri Aug 26, 2016 9:44 am
Hi Ken, I've got the wheel boxes, rack and motor here in Kano, I have a td5 Defender as my tow barge in the UK, but never looked at its wiper arms, will do in late Sept when I'm back :wink:
Fri Aug 26, 2016 2:14 pm
Brain picking time again, I'm needing a wash and 2 speed wipe switch, in my old Cox incarnation I used a rotary switch and 2 speed wiper motor out of a scrap 3lt Rover, I'm guessing later Coupes fitted Metro switches, anybody got one under the bench they don't want? it's wrestling with multi coloured spaghetti time!
Tue Apr 18, 2017 2:12 pm
Think I have a set of dip/main beam/indicator and Horn, along with Wipers on the other side, that clamp around the steering column, somewhere in the garage.
The sort that was fitted to most British cars of the time
Will look tonight.
Tue Apr 18, 2017 3:46 pm
Would look like this if I remember correctly.
Tue Apr 18, 2017 3:50 pm
Good news and bad news
Good news I've found it and the wiper stalk works.
Bad new is the headlight stalk has melted, I guess from feeding halogen bulbs with no relay :(
Tue Apr 18, 2017 8:52 pm
Hi Ken thanks for the good and bad news :lol: I have a Peugeot switch for the indicators & lights if your wiper switch can be removed from the mounting plate ie 2 separate switched on one plate I could use it, are you going to Stoneliegh? or tell me what you want for it + postage and send to Northampton
Wed Apr 19, 2017 6:22 am
I decided to remove the broken part, as it forms part of the pivot and a cover as well.
If you PM me an address I'll get it posted.
Don't worry about costs, as one of your fellow countrymen has promised me a significant share of a large sum of money,
in return for a small up-front payment. Just waiting on the bank transfer to come thru.
:lol:
Thu Apr 20, 2017 10:45 pm
Hi Ken, you have PM and many thanks for your generous offer, my fellow Nigerian keeps making me the same offer to lace a little slush money into his account so that he can get funds from his late father, brother, uncle or cousin's frozen account in some far off and little known place :lol: it's not just you lot in the far north of Scotland, do you come south at all? it will be a rush but I plan to be at the GTM stand on 1st May if I can get loaded in time I will bring my Jedi it it could be my 1st drive since September 2015 off the trailer and onto the GTM club stand :wink:
Fri Apr 21, 2017 6:14 am
Was hoping to make Blydon Park on the Sunday, but will need Sat/Monday to travel down.
But as the car isn't MOTed yet it's still just a hope.
Fri Apr 21, 2017 9:01 am
I have not posted for a while, not because I've done nothing but not a lot to show for the efforts worthy of a picture :wink: My wiring loom had to be cut and shut some bits of it not needed others to short or long because its now LH drive, uncle Kens donated wash & wiper switch is wired in and the Peugeot headlight switch is wired in with relays, Last weekend was a long holiday for the end of Ramadan which was a big help to get thing sorted, I took out the front subframe to replace my rack wedge blocks with some of Allen RossaBits wedgies with proper U bolts not my home made codged up jobbies, I also took the plunge and fitted 2 universal joints into the steering column to get a better alignment.
Next question what turn and side lights (Metro ??) were used on later coupes and has anybody got a pair for sale
Thu Jun 29, 2017 10:08 am
Nice new battery box
Wed Jul 05, 2017 6:38 am
mk2 handbrake
Wed Jul 05, 2017 6:39 am
