It is currently Fri Nov 27, 2026 9:14 am
Post new topic Reply to topic  [ 379 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 26  Next
Fitted Sanzomats MGF speedo cable, I had to recut the thread on the little cast aluminium mounting block from 3/4" tread to M18 x1.5 for the cable nut to fit
Thanks Sanzo
Sun Jun 05, 2016 2:38 pm
Water hoses and header tank in position
Sun Jun 05, 2016 2:39 pm
Remote oil filter in position, still have a Laminova oil to water heat exchanger and more fittings to collect on my next UK visit to complete the job
Sun Jun 05, 2016 2:42 pm
Thanks to my Muslin brothers having 2 days holiday for the end of Ramadan I made a hydraulic hand braked using my ex Jedi clutch master cylinder, (it now has a cable operated clutch)
Thu Jul 07, 2016 1:34 pm
A hydraulic handbrake, that is a nice idea for the future!
Nice to work on the car with the loose rear end, but how is the rear end fixed?
Harold
Sat Jul 09, 2016 3:26 pm
I had no other option, no handbrake or Hydraulic as I'm using the same Toyota calipers front and rear :wink:
Sun Jul 10, 2016 5:36 am
John,
Are you using separate/additional rear calipers for the hydraulic handbrake?
I ask this as you have used an integral reservoir master cylinder rather than using a remote type.
Hydraulic handbrakes normally feed through a remote type master cylinder with the main rear brake line as the feed to the cylinder and the output going to the rear calipers.
Doug.
Wed Jul 13, 2016 8:34 am
Cheers Doug, you just spoiled my day :oops: luckily I do have a remote cylinder that could be plumbed inline.
Thanks for making me think a bit more
Wed Jul 13, 2016 9:46 am
Don't worry John - guess who else made this basic error :oops:
Mon Jul 25, 2016 3:41 pm
We all have our moments, engage brain before taking action :lol: and I was feeling quite pleased about my hand brake solution :!:
Tue Jul 26, 2016 6:35 am
Did anybody convert the BL rod change to cable operation and what bits were used?
Thu Jul 28, 2016 8:33 am
Certainly had the conversation about doing it on the turbo Cox, I think it would be very beneficial.
Thu Jul 28, 2016 10:44 am
I can't get away with cables in Historic racing so I have designed a better version of the Heerey/Coupe original using these rather marvellous products.
http://www.igus.co.uk/wpck/2507/igubal_ ... ?C=GB&L=en
Also incorporating some UJ's so it is a bit more adjustable, the weak point is always the "pendulum" bit that goes under the gearbox!
i post some drawing when I've worked it all out!
Thu Jul 28, 2016 11:25 am
I made a new gear lever end which is very free moving that is pictured in my earlier posts, but find the rod into the gear box is quite stiff with its new seals, not a nice change at all :cry:
Thu Jul 28, 2016 11:38 am
Hi Grizz,
I'm not sure when the rod change box was introduced, but would think for (pre 72??) historic racing you would be limited to the old remote change, which I had cut into 2 pieces in my old Cox.
Thu Jul 28, 2016 12:08 pm
