kano nordie
 Re: Kano Coupe
Fitted Sanzomats MGF speedo cable, I had to recut the thread on the little cast aluminium mounting block from 3/4" tread to M18 x1.5 for the cable nut to fit Thanks Sanzo John
| Sun Jun 05, 2016 2:38 pm |
kano nordie
 Re: Kano Coupe
Water hoses and header tank in position
| Sun Jun 05, 2016 2:39 pm |
kano nordie
 Re: Kano Coupe
Remote oil filter in position, still have a Laminova oil to water heat exchanger and more fittings to collect on my next UK visit to complete the job
| Sun Jun 05, 2016 2:42 pm |
kano nordie
 Re: Kano Coupe
Thanks to my Muslin brothers having 2 days holiday for the end of Ramadan I made a hydraulic hand braked using my ex Jedi clutch master cylinder, (it now has a cable operated clutch) John
| Thu Jul 07, 2016 1:34 pm |
Yoda74
 Re: Kano Coupe
A hydraulic handbrake, that is a nice idea for the future! Nice to work on the car with the loose rear end, but how is the rear end fixed?
Harold
| Sat Jul 09, 2016 3:26 pm |
kano nordie
 Re: Kano Coupe
I had no other option, no handbrake or Hydraulic as I'm using the same Toyota calipers front and rear John
| Sun Jul 10, 2016 5:36 am |
minitici
 Re: Kano Coupe
John, Are you using separate/additional rear calipers for the hydraulic handbrake?
I ask this as you have used an integral reservoir master cylinder rather than using a remote type.
Hydraulic handbrakes normally feed through a remote type master cylinder with the main rear brake line as the feed to the cylinder and the output going to the rear calipers.
Doug.
| Wed Jul 13, 2016 8:34 am |
kano nordie
 Re: Kano Coupe
Cheers Doug, you just spoiled my day  luckily I do have a remote cylinder that could be plumbed inline. Thanks for making me think a bit more John
| Wed Jul 13, 2016 9:46 am |
minitici
 Re: Kano Coupe
kano nordie wrote: Cheers Doug, you just spoiled my day  luckily I do have a remote cylinder that could be plumbed inline. Thanks for making me think a bit more John Don't worry John - guess who else made this basic error
| Mon Jul 25, 2016 3:41 pm |
kano nordie
 Re: Kano Coupe
We all have our moments, engage brain before taking action  and I was feeling quite pleased about my hand brake solution John
| Tue Jul 26, 2016 6:35 am |
kano nordie
 Re: Kano Coupe
Did anybody convert the BL rod change to cable operation and what bits were used? John
| Thu Jul 28, 2016 8:33 am |
 Re: Kano Coupe
kano nordie wrote: Did anybody convert the BL rod change to cable operation and what bits were used? John Certainly had the conversation about doing it on the turbo Cox, I think it would be very beneficial. Neil
| Thu Jul 28, 2016 10:44 am |
grizzler73
 Re: Kano Coupe
I can't get away with cables in Historic racing so I have designed a better version of the Heerey/Coupe original using these rather marvellous products. http://www.igus.co.uk/wpck/2507/igubal_ ... ?C=GB&L=enAlso incorporating some UJ's so it is a bit more adjustable, the weak point is always the "pendulum" bit that goes under the gearbox! i post some drawing when I've worked it all out!
| Thu Jul 28, 2016 11:25 am |
kano nordie
 Re: Kano Coupe
I made a new gear lever end which is very free moving that is pictured in my earlier posts, but find the rod into the gear box is quite stiff with its new seals, not a nice change at all John
| Thu Jul 28, 2016 11:38 am |
kano nordie
 Re: Kano Coupe
grizzler73 wrote: I can't get away with cables in Historic racing so I have designed a better version of the Heerey/Coupe original using these rather marvellous products. http://www.igus.co.uk/wpck/2507/igubal_ ... ?C=GB&L=enAlso incorporating some UJ's so it is a bit more adjustable, the weak point is always the "pendulum" bit that goes under the gearbox! i post some drawing when I've worked it all out! Hi Grizz, I'm not sure when the rod change box was introduced, but would think for (pre 72??) historic racing you would be limited to the old remote change, which I had cut into 2 pieces in my old Cox. John
| Thu Jul 28, 2016 12:08 pm |
